that looked to fix it… though I’ve thought the same many times, so we’ll see!
Well you can let us know.
I think I figured it out; I don’t have any tearing at first. If I enable picom and then disable it, only then I get tearing. Very weird…
I think it’s a picom bug, this behavior can’t be reproduced with xcompmgr. Closing this then… for now
HAHAHA and now my frustration is beyond limits. It still tears!
So I decided to ditch everything and try all over. I have no /etc/X11/xorg.conf, and no nvidia driver. I have /etc/X11/xorg.conf.d/20-intel.conf with this:
Section "Device"
Identifier "Intel Graphics"
Driver "i915"
Option "TearFree" "true"
EndSection
My system does not boot using the above, same if I change it to intel. If I change it to modesetting (as per inxi, loaded: modesetting) then it boots but still tears.
inxi: http://ix.io/3uXc
Any ideas?
Change it to what i had before and try. This is what it showed for /etc/x11/xorg.conf.d/20-intel.conf
things like flameshot and simplescreenrecorder are broken.
Btw how are they broken?
Most of the time they work with those drivers, but sometimes they have weird graphical artifacts.
I already did.
you can try the intel driver with this parameter Option "DRI" "2"
no, doesn’t work. i’ll just live w/ a compositor for now…
