Everytime I’d take a screenshot whether it be by flameshot, spectacle, or OBS-Studio, I always get this bug (external link download to MEGA)where it takes a screenshot of the desktop, or another window present. What should be done to fix this?
~ » neofetch mika@Luna
./o. mika@Luna
./sssso- ---------
`:osssssss+- OS: EndeavourOS Linux x86_64
`:+sssssssssso/. Host: Aspire A514-53 V1.16
`-/ossssssssssssso/. Kernel: 5.16.4-arch1-1
`-/+sssssssssssssssso+:` Uptime: 44 mins
`-:/+sssssssssssssssssso+/. Packages: 1288 (pacman), 22 (flatpak)
`.://osssssssssssssssssssso++- Shell: zsh 5.8
.://+ssssssssssssssssssssssso++: Resolution: 1920x1080
.:///ossssssssssssssssssssssssso++: DE: Plasma 5.23.5
`:////ssssssssssssssssssssssssssso+++. WM: KWin
`-////+ssssssssssssssssssssssssssso++++- Theme: Breeze Light [Plasma], Arc-Dark [GTK2/3]
`..-+oosssssssssssssssssssssssso+++++/` Icons: [Plasma], breeze [GTK2/3]
./++++++++++++++++++++++++++++++/:. Terminal: tilix
`:::::::::::::::::::::::::------`` CPU: Intel i3-1005G1 (4) @ 1.200GHz
GPU: Intel Iris Plus Graphics G1
Memory: 4712MiB / 7626MiB
~ » inxi -Fazy mika@Luna
Kernel: 5.16.4-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=611866a2-d11d-4442-b786-7263350a926f rw quiet
cryptdevice=UUID=b9e892a4-f9f8-403f-b606-27b363a97077:luks-b9e892a4-f9f8-403f-b606-27b363a97077
root=/dev/mapper/luks-b9e892a4-f9f8-403f-b606-27b363a97077
resume=UUID=665bc4e0-0faa-4bac-9fe7-ecfb2dfef3a7 loglevel=3 nowatchdog
nvme_load=YES
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 info: docker wm: kwin_x11 vt: 7
dm: LightDM 1.30.0 Distro: EndeavourOS base: Arch Linux
Type: Laptop System: Acer product: Aspire A514-53 v: V1.16
Mobo: IL model: Sneezy_IL v: V1.16 serial: <superuser required>
UEFI: Insyde v: 1.16 date: 01/18/2021
Battery:
ID-1: BAT0 charge: 32.6 Wh (100.0%) condition: 32.6/53.0 Wh (61.6%)
volts: 16.6 min: 15.4 model: PANASONIC KT004 AP19B5L type: Li-ion
serial: <filter> status: Full cycles: 386
Device-1: hid-f4:73:35:09:1d:b5-battery model: Keyboard K380 serial: N/A
charge: N/A status: Discharging
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xA6
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache:
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1160 high: 1180 min/max: 400/3400 scaling:
driver: intel_pstate governor: performance cores: 1: 1180 2: 1141 3: 1165
4: 1156 bogomips: 9524
Vulnerabilities:
Type: itlb_multihit status: KVM: VMX disabled
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl
Type: spectre_v1
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-6:4
chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (20.0x11.2")
s-diag: 582mm (22.9")
Monitor-1: HDMI1 res: 1920x1080 dpi: 102 size: 480x270mm (18.9x10.6")
diag: 551mm (21.7")
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.3.5
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0401
Device-2: C-Media USB PnP Sound Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1:2 chip-ID: 0d8c:013a
class-ID: 0300
Sound Server-1: ALSA v: k5.16.4-arch1-1 running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.44 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
IF-ID-1: br-2b12a360e95c state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-4: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IF-ID-5: veth745a397 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Bluetooth:
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-10:5 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: up address: see --recommends
RAID:
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.4 TiB used: 693.19 GiB (48.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: HBRPEKNX0202A
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: G002 temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:7 vendor: Intel model: HBRPEKNX0202AO
size: 27.25 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: K5110440 temp: 46.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 69.85 GiB size: 68.2 GiB (97.64%) used: 25.85 GiB (37.9%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-b9e892a4-f9f8-403f-b606-27b363a97077
ID-2: /boot/efi raw-size: 489 MiB size: 488 MiB (99.80%)
used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 162.98 GiB size: 159.36 GiB (97.78%)
used: 102.21 GiB (64.1%) fs: ext4 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-05a5ae76-4f16-418d-b6dd-70173c6d5b5e
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 10.25 GiB used: 7.8 MiB (0.1%)
priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 55.0 C mobo: N/A
Fan Speeds (RPM): N/A
Processes: 287 Uptime: 45m wakeups: 3 Memory: 7.45 GiB used: 4.9 GiB (65.8%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0
Packages: 1310 pacman: 1288 lib: 286 flatpak: 22 Shell: Zsh v: 5.8
running-in: tilix inxi: 3.3.12
