Hi there, apologies if this is the wrong category to post this in. I am new to EndeavourOS and got it installed using the default bundled KDE + Kwin and wanted to explain a workflow process that I use at home.
I currently have two monitors, a middle one that I plug into my work laptop during the day and when I’m done work, I want the monitor to go back to my desktop running EndeavourOS with it being the primary monitor.
Before in Windows 11, I would use Windows + P to select “Second Screen Only” so that the monitor would automatically switch to my work laptop. This lets my second screen be the primary of my desktop, and then when I am done, I would select “Extend” and unplug the cable from my laptop - giving me 2 screens again for my desktop and the middle screen would automatically be set as my primary.
I was trialing a fresh install of EndeavourOS and tried the same workflow, things work just fine - however when I unplug the laptop and select “Extend Left” using Meta + P, the second monitor stays as the primary and I have to manually reselect the main monitor as the primary again.
I was wondering if there was a way to save monitor profiles or easily switch it without having to manually select the “Set as Primary” every single time. Thanks in advance!
