Below is my smb.conf
It’s modified from one I had working in Manjaro where they have a package for config that gets the dolphin and nemo filesharing plugins working properly (*I generally prefer Endeavour after switching, this is the one area that’s an issue for me)
In addition to below I’ve set smbpasswd for my user account and added it to sambashare group after creating that group and rebooted/etc.
I can create shares fine if I add them manually to the file, and they work. But if I want to be able to add/remove through GUI, it will “pretend” to add the share in both nemo and dolphin, but it doesn’t actually show up, and I have no idea why. The directory is the /var/lib/samba/usershare. I have verified that, and Dolphin or Nemo are creating files to provide context to point to the path to the files, and since I can add a share on the same drive manually I don’t think it can be some kind of permission issue for the samba service, so I’m at a loss.
[global]
workgroup = WORKGROUP
dns proxy = no
log file = /var/log/samba/%m.log
max log size = 1000
client min protocol = SMB2
server role = standalone server
passdb backend = smbpasswd
# obey pam restrictions = yes
# unix password sync = yes
# passwd program = /usr/bin/passwd %u
# passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
# pam password change = yes
map to guest = Bad User
# usershare allow guests = yes
name resolve order = lmhosts bcast host wins
security = user
guest account = nobody
usershare path = /var/lib/samba/usershare
usershare max shares = 100
usershare owner only = false
wins support = yes
force create mode = 0070
force directory mode = 0070
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
show add printer wizard = no
#[homes]
# comment = Home Directories
# browseable =no
# read only = yes
# create mask = 0700
# directory mask = 0700
# valid users = %S
#[printers]
# comment = All Printers
# browseable = no
# path = /var/spool/samba
# printable = yes
# guest ok = no
# read only = yes
#[print$]
# comment = Printer Drivers
# path = /var/lib/samba/printers
# browseable = yes
# read only = yes
# guest ok = no
# valid users = xanas
[Video]
path = /mnt/16TB_BTRFS/Video
browseable = yes
guest ok = no
