Hello Everbody ,
does anybody know, where i can take the temperatures from my 8 cores?
I want to add them to conky!
Thanks in advance!
Andi
Hello Everbody ,
Thanks in advance!
Andi
Not available per core, as far as I can see. I just pick the overall up from sensors, and conky that. Here;s the sensors output:
┌07:42:31 WD= [~]
└───freebird@nest ─▶$ sensors
nvme-pci-0300
Adapter: PCI adapter
Composite: +44.9°C (low = -60.1°C, high = +89.8°C)
(crit = +94.8°C)
amdgpu-pci-0800
vddgfx: 1.19 V
fan1: 696 RPM (min = 0 RPM, max = 4500 RPM)
edge: +54.0°C (crit = +94.0°C, hyst = -273.1°C)
power1: 42.03 W (cap = 135.00 W)
k10temp-pci-00c3
Tctl: +61.8°C
Tdie: +61.8°C
Tccd1: +60.0°C
and I use the Tccd1 value usually. This is what I end up with:
(bottom of the midddle section)
