Running EndeavourOS in Hyper-V
I’ve been able to run EndeavourOS in Hyper-V, however, X does not start.
I’ve had this issue when I attempted Arch installation in Hyper-V, but with Arch, the installation is complete before X is started.
Note that many distributions have no problem running in Hyper-V with their desktop environments, so I know that there is likely a solution, I’m just new to the bare Arch world.
Could you please post your Xorg log, it may be helpful in finding out why it isn’t starting
/var/log/Xorg.0.log
Will try to grab that when I get home, thanks!
Hyper-V is not the Problem
Edit
Maybe i was to quick, the graphical installer worked but not booting after a successfull install.
Can confirm that adding a RemoteFX 3D Video Adapter in hyper-v will solve the problem.
endevour
