Hi ,
As the title says I have the Asus Crosshair x670E ROG which comes with the SupremeFX 7.1 Surround Sound High Definition Audio CODEC ALC4082.
The problem is that I have this buzzing annoying sound all over the speakers when playing games.
That means when I stress the PC I have these buzzing sounds all over the speakers.
If I switch to my external USB Focusrite sound card everything is working fine.
If I disable the Audio from the BIOS again everything is working fine but without sound.
I have tried a lot of things with pipewire settings, bios settings but without success.
I have tried to create a file /etc/modprobe.d/alsa-base.conf but nothing is working , I always get a line error “options” are invalid line …
If there is anything I can do to fix this please let me know , otherwise I guess I will have to buy another sound card.
Thanks in advance for all the suggestions…
