I was having a issue in which when using rofi menu tmux which I have recently installed is not showing up. I have seen there are some issue when some applications are installed out side of the $PATH. However, this was installed with pacman and I doubt this is the issue. How can I get it to show up?
yes it’s right you can too
sometimes i like best that things are in root folder
but here I will probably use as you said
nano $HOME/.local/share/applications/tmux.desktop
