Luke’s Tech reviewed the ARM Edition on his YouTube channel.
It was a mostly positive review. Kudos to @Pudge and others who have contributed to the ARM development.
guess he not install correct or removed alot unless @Pudge change script? i’d say that just base install of arch with some EndeavourOS packages. Also usb port on 8Gb pi4 work for long times . I will watch all…
for share @sradjoker
Edit i no install EOS on pi4 in lot time maybe install script change . had this before when thing go side way ( script part fail ) you end with arch+ few items of endeavouros
Edit 2… Nothing wrong with install process Pudge did fantatsic work. it better this way + learn more
EndeavourOs no want be same every other distro !!
Edit 3… " need be arch base system " That no a must have , it advice + using iso is great idea if any mistake made it no make problem in your main device . iso use save you from that worry .
