(Resuelto) X falla con segmentation fault luego de actualizar
Hola gente.
Alguien que me ayude, por favor. Ayer actualicé el sistema via pacman -Syu y luego de reiniciar no puedo entrar en el entorno gràfico.
Esto es lo que me sale en .local/share/xorg/Xorg.0.log
[ 2172.384] (EE) libinput: PC Speaker: Failed to create a device for /dev/input/event7
[ 2172.384] (EE) PreInit returned 2 for “PC Speaker”
[ 2172.384] (II) UnloadModule: “libinput”
[ 2172.384] (II) systemd-logind: releasing fd for 13:71
[ 2172.814] (II) intel(0): EDID vendor “CMN”, prod id 4160
[ 2172.814] (II) intel(0): Printing DDC gathered Modelines:
[ 2172.814] (II) intel(0): Modeline "1366x768"x0.0 76.42 1366 1502 1532 1592 768 776 788 800 -hsync -vsync (48.0 kHz eP)
[ 2175.715] (EE)
[ 2175.715] (EE) Backtrace:
[ 2175.716] (EE) 0: /usr/lib/Xorg (xorg_backtrace+0x5b) [0x56099c978ddb]
[ 2175.716] (EE) 1: /usr/lib/Xorg (0x56099c82d000+0x156a15) [0x56099c983a15]
[ 2175.716] (EE) 2: /usr/lib/libpthread.so.0 (0x7f56f317d000+0x13870) [0x7f56f3190870]
[ 2175.716] (EE) 3: /usr/lib/Xorg (0x56099c82d000+0xc5dce) [0x56099c8f2dce]
[ 2175.716] (EE) 4: /usr/lib/Xorg (0x56099c82d000+0x1d00e1) [0x56099c9fd0e1]
[ 2175.716] (EE) 5: /usr/lib/Xorg (0x56099c82d000+0xd7de2) [0x56099c904de2]
[ 2175.716] (EE) 6: /usr/lib/Xorg (0x56099c82d000+0xdc72c) [0x56099c90972c]
[ 2175.716] (EE) 7: /usr/lib/Xorg (0x56099c82d000+0xde4aa) [0x56099c90b4aa]
[ 2175.717] (EE) 8: /usr/lib/Xorg (0x56099c82d000+0xdd656) [0x56099c90a656]
[ 2175.717] (EE) 9: /usr/lib/Xorg (0x56099c82d000+0x3b07a) [0x56099c86807a]
[ 2175.717] (EE) 10: /usr/lib/libc.so.6 (__libc_start_main+0xd5) [0x7f56f2fd3b25]
[ 2175.717] (EE) 11: /usr/lib/Xorg (_start+0x2e) [0x56099c8684ce]
[ 2175.717] (EE)
[ 2175.717] (EE) Segmentation fault at address 0x20
[ 2175.717] (EE)
Fatal server error:
[ 2175.717] (EE) Caught signal 11 (Segmentation fault). Server aborting
[ 2175.717] (EE)
[ 2175.717] (EE)
Please consult the The X.Org Foundation support
Hola, gente. Aún tengo el problema. Por ahora estoy usando Sway porque wayland funciona. Pero no puedo usar Spectrwm o Qtile porque sigo sin poder iniciar X. ¿Será un problema de bug en xorg-server? ayuda se agradece.
El problema era el kernel. Lo solucioné instalando la versión lts.
