Before resolving dependencies was faster.
Nowadays both yay and pacman are having this issue.
Can you provide some context here? How long does it take?
Also, can we see your inixi -Fxxxz
so we can see your hardware specifics?
When was this before?
What changed?
What timescales are you talking about?
Without further information I’d guess the problem has to do with sub-optimal mirrors or slow internet connection.
After resolving dependencies everything downloads so fast.
AFAIK i have a good internet connection.
Is this?
Kernel: 5.17.4-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: EndeavourOS
base: Arch Linux
Type: Laptop System: LENOVO product: 81MT v: Lenovo V145-15AST
serial: Chassis: type: 10 v: Lenovo V145-15AST
serial:
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55724 WIN
serial: UEFI: LENOVO v: 8ZCN27WW(V2.06)
date: 01/12/2021
Battery:
ID-1: BAT1 charge: 18.8 Wh (94.9%) condition: 19.8/30.0 Wh (66.0%)
volts: 8.3 min: 7.6 model: 0x4C 0x47 0x43 0x00 0x31 0x PABAS0241231
type: Li-ion serial: status: N/A cycles: 280
Info: dual core model: AMD A6-9225 RADEON R4 5 COMPUTE CORES 2C+3G bits: 64
type: MCP smt: arch: Excavator rev: 0 cache: L1: 192 KiB
L2: 2 MiB
Speed (MHz): avg: 2937 high: 2944 min/max: 1300/2600 boost: enabled
cores: 1: 2931 2: 2944 bogomips: 10385
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Lenovo
driver: amdgpu v: kernel ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
Device-2: Chicony EasyCamera type: USB driver: uvcvideo bus-ID: 1-1.3:4
chip-ID: 04f2:b628 class-ID: 0e02 serial:
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1
compositor: xfwm v: 4.16.1 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x15db res: 1366x768
hz: 60 dpi: 101 size: 344x193mm (13.54x7.6") diag: 394mm (15.5") modes:
max: 1366x768 min: 640x480
OpenGL: renderer: AMD STONEY (LLVM 13.0.1 DRM 3.44 5.17.4-arch1-1)
v: 4.5 Mesa 22.0.1 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:15b3 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a class-ID: 0403
Sound Server-1: ALSA v: k5.17.4-arch1-1 running: yes
Sound Server-2: PulseAudio v: 15.0 running: no
Sound Server-3: PipeWire v: 0.3.50 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac:
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8821ce v: N/A pcie: speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
IF: wlan0 state: up mac:
Bluetooth:
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-1.2:3 chip-ID: 0bda:c024 class-ID: e001 serial:
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: disabled
Local Storage: total: 931.51 GiB used: 31.31 GiB (3.4%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: rev: LCM2 scheme: GPT
ID-1: / size: 90.93 GiB used: 31.17 GiB (34.3%) fs: ext4 dev: /dev/sda23
ID-2: /boot/efi size: 871.3 MiB used: 134.5 MiB (15.4%) fs: vfat
dev: /dev/sda19
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda16
System Temperatures: cpu: 67.8 C mobo: N/A gpu: amdgpu temp: 67.0 C
Fan Speeds (RPM): N/A
Processes: 171 Uptime: 17m wakeups: 1 Memory: 3.31 GiB
used: 1.49 GiB (45.1%) Init: systemd v: 250 Compilers: gcc: 11.2.0
Packages: pacman: 1283 Shell: Zsh v: 5.8.1 running-in: xfce4-terminal
inxi: 3.3.15
Can you share an objective number for what you mean as “slow”?
ok.
resolving dependencies took 1 s or somethin closer before.
but now it takes approx 1min
