Good morning, everyone!
I usually have a lot of visual glitches with Wayland. Is it possible to replace it with XOrg?
If so, can someone point me towards a tutorial?
Thanks!
Thanks!
When you’re at the log in screen, click on password field and you should see gear icon on bottom right. You can click and choose Xorg. I think default Gnome is Wayland.
Alternatively, you could edit /etc/gdm/custom.conf
# GDM configuration storage
[daemon]
# Uncomment the line below to force the login screen to use Xorg
#WaylandEnable=false
[security]
[xdmcp]
[chooser]
[debug]
# Uncomment the line below to turn on debugging
#Enable=true
and change
to
WaylandEnable=false
This worked! I didn’t even bother checking that gear because I only installed gnome this time. Thanks!
@pebcak thank you too for your suggestion on how to change it for GDM as well. =)
Remember to mark the post as the Solution.
I didn’t know we could do that. Thanks for the feedback!
My language and keyboard is French, so if I made the above change would the language and keyboard revert to English? If so how to change in xorg?
Michael
Myself, I do use Gnome on Wayland on my laptop.
However testing the above and switching to Xorg did change neither the language nor the keyboard layout on this system.
