Removing Gnome and KDE safely
I installed EOS about 3 years back and chose both Gnome and KDE as my DEs in the installer. However, I immediately switched to i3 and haven’t looked back. I was wondering if there was a way I could safely remove gnome and KDE without breaking my system. I have timeshift enabled with a hook after any Pacman/yay calls for some insurance.
There are lots of ways. All of them require some care. Here is how I would do it.
  1. Remove gnome - yay -Rc gnome - Review the list of packages to be removed. If there is anything that you still want, make a note and reinstall it afterwards
  2. Remove plasma - yay -Rc plasma - Review the list of packages to be removed. If there is anything that you still want, make a note and reinstall it afterwards
  3. Clean up orphans - yay -Yc - Review the list of packages to be removed. If there is anything that you still want, mark it as explicitly installed before removing
Thank you dalto, this did the trick for me!
