Reflector-simple not working - locale issues
Hi everyone!
I cannot start the programme ‘reflector-simple’. I tried this from the eos-welcome app, the kde launcher and from the terminal.
The terminal gives me the following error message:
[ ~]$ reflector-simple
reflector-simple: info: reading file /etc/reflector-simple-tool.conf
reflector-simple: info: reading file /etc/reflector-simple.conf
(process:18845): Gtk-WARNING **: 16:03:28.479: Locale not supported by C library.
        Using the fallback 'C' locale.
Unable to parse command line: Invalid byte sequence in conversion input
I’ve already tried running locale-gen, but this does not solve the issue.
What can I try to solve this issue?
Thanks in advance for anyone with ideas!
That only generates the locale. See: https://wiki.archlinux.org/title/Locale#Setting_the_system_locale
What is the output of the following:
cat /etc/locale.conf
grep -ve ^# /etc/locale.gen
localectl
Thanks for your quick response! Here is the output of the three commands.
LANG=en_GB.UTF-8$
LC_ADDRESS=en_GB.UTF-8$
LC_IDENTIFICATION=en_GB.UTF-8$
LC_MEASUREMENT=en_GB.UTF-8$
LC_MONETARY=en_GB.UTF-8$
LC_NAME=en_GB.UTF-8$
LC_NUMERIC=en_GB.UTF-8$
LC_PAPER=en_GB.UTF-8$
LC_TELEPHONE=en_GB.UTF-8$
LC_TIME=en_GB.UTF-8$
en_GB.UTF-8 UTF-8
en_US.UTF-8 UTF-8
localectl
System Locale: LANG=en_GB.UTF-8
VC Keymap: us-acentos
X11 Layout: us
X11 Variant: altgr-intl
What’s the output when you run:
sudo locale-gen
and,
locale -a
Your /etc/locale.conf has dollar signs on all lines.
Should remove them.
