I am running a PC as a kind of server for my family. At the moment I am using dovecot as IMAP-server and fetchmail to collect all the mail for the users. After collecting the mail it is delivered via postfix to the IMAP-server and distributed into the particular mailboxes.
Looking in the Arch wiki I found that fetchmail seems not to be the recommended solution as mail retreaval agent (MRA). But there is no recommendation what to use instead. I only found a list of other MRAs like fdm, getmail or mpop. I am not sure if I should replace fetchmail or not.
Which MRAs do you use and why?
