Hello everyone, I’m sorry that this, of all things, is the first post I create after my introduction, but I ran into some problems I couldn’t solve by myself.
First: My laptop (a Lenovo IdeaPad 5) has a WiFi card from Realtek, namely an RTL8852AE. I used to easily get this card to run by connecting my phone via USB, install rtw89-dmks-git from the AUR, and finally doing a quick sudo modprobe rtw89pci
. Now, I’ve seen that after every kernel change the thing has to be rebuild, so I did as instructed and had yay rebuild it—at least I assume that’s what I did, because yay asked me if I wanted to “clean build” it and I told it to do so.
Now, however, I can’t activate it, as the modprobe
command just returns an error:
sudo modprobe -v rtw89pci
insmod /lib/modules/5.16.0-arch1-1/updates/dkms/rtw89pci.ko.zst
modprobe: ERROR: could not insert 'rtw89pci': Exec format error
This means that my laptop currently has no WiFi. I can work around that, but it is a tad annoying—aka I’m a bit freaked out.
Second issue: Before the most recent updates, booting and shutting down would show just a few messages, usually something about a dog that didn’t stop. I like dogs, so I never worried too much about it. “Let it play,” I thought. Ahem … Anyway, ever since today, my screen is flooded with messages during boot and shutdown processes. Most of them, again, seem fine, like:
Unmounting this and that …
Finished unmounting …
Detaching this and that …
Finished detaching …
etc. It’s a bit unusual to see all of this spelled out to me, but it’s nothing I should worry about, I think.
What I do worry about, however, is that the laptop won’t turn off on its own any more. After all these messages it now stops at kvm: exiting hardware virtualization
and it stays that way, until I hold down the power button.
If anyone has a great idea or two on how to fix these issues, I’d be very grateful.
Here is some information about my system:
[ahf@xenon ~]$ inxi --admin --verbosity=7 --filter --width
Kernel: 5.16.0-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=07cc1835-beed-4778-904c-f4c43240b11a rw quiet
resume=UUID=b6a9446f-347e-4497-ac8d-a664aa56a419 loglevel=3 nowatchdog
nvme_load=YES acpi_backlight=video
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 82LM v: IdeaPad 5 14ALC05
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 14ALC05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: G5CN20WW(V1.08)
date: 06/30/2021
Battery:
ID-1: BAT1 charge: 49.4 Wh (85.6%) condition: 57.7/56.5 Wh (102.2%)
volts: 12.4 min: 11.5 model: 0x53 0x4D 0x50 0x00 0x32 0x30 0x 0x4C 0x31
0x39 0x4D 0x33 0x50 0x5650
type: Li-ion serial: <filter> status: Discharging cycles: 8
Memory:
RAM: total: 15.03 GiB used: 2.48 GiB (16.5%)
RAM Report:
permissions: Unable to run dmidecode. Root privileges required.
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache:
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1396 high: 1397 min/max: 1400/4056 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
3: 1397 4: 1394 5: 1396 6: 1395 7: 1397 8: 1397 9: 1396 10: 1397 11: 1397
12: 1397 bogomips: 50326
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy
constant_tsc cpb cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae
pat pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Vulnerabilities:
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl
Type: spectre_v1
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: conditional, RSB filling
Device-1: AMD Lucienne vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 04:00.0 chip-ID: 1002:164c class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 174f:2459 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2")
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: AMD RENOIR (DRM 3.44.0 5.16.0-arch1-1 LLVM 13.0.0)
v: 4.6 Mesa 21.3.3 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.16.0-arch1-1 running: yes
Sound Server-2: JACK v: 1.9.19 running: no
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_pci v: kernel modules: rtw89pci port: 2000
bus-ID: 03:00.0 chip-ID: 10ec:8852 class-ID: 0280
IF-ID-1: enp4s0f4u2 state: unknown speed: -1 duplex: half mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global
broadcast: <filter>
IP v6: <filter> type: noprefixroute scope: link
IF-ID-2: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> virtual: stable-privacy scope: link
WAN IP: <filter>
Bluetooth:
Device-1: Xiaomi Mi/Redmi series (RNDIS) type: USB driver: rndis_host
v: kernel bus-ID: 3-2:5 chip-ID: 2717:ff80 class-ID: 0a00 serial: <filter>
Report: This feature requires one of these tools: hciconfig/bt-adapter
Device-2: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-4:3 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Report: ID: hci0 rfk-id: 2 state: up address: N/A
Logical:
Message: No logical block device data found.
RAID:
Message: No RAID data found.
Local Storage: total: 592.04 GiB used: 31.64 GiB (5.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital
model: PC SN730 SDBPNTY-512G-1101 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 11190001 temp: 25.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk
model: SSD PLUS 240GB size: 115.1 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> scheme: GPT
Message: No optical or floppy data found.
ID-1: / raw-size: 98.27 GiB size: 96.16 GiB (97.86%) used: 31.64 GiB (32.9%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 07cc1835-beed-4778-904c-f4c43240b11a
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: C309-0161
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 16.54 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: b6a9446f-347e-4497-ac8d-a664aa56a419
Unmounted:
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM_DRV
uuid: 3828-0EFF
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 475.69 GiB fs: ntfs
label: Windows-SSD uuid: 6828297728294602
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs
label: WINRE_DRV uuid: 1C2229E72229C69C
USB:
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-3:2 info: Syntek Integrated Camera type: Video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
chip-ID: 1d6b:0003 class-ID: 0900
Device-1: 2-2:2 info: SanDisk Extreme Pro type: Mass Storage driver: uas
interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 896mA chip-ID: 0781:5588
class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:5 info: Xiaomi Mi/Redmi series (RNDIS)
type: Bluetooth,CDC-Data driver: rndis_host interfaces: 2 rev: 2.1
speed: 480 Mb/s power: 500mA chip-ID: 2717:ff80 class-ID: 0a00
serial: <filter>
Device-2: 3-3:2 info: Shenzhen Goodix Goodix FingerPrint Device
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 27c6:55a2 class-ID: ef00
Device-3: 3-4:3 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 35.1 C mobo: 35.0 C gpu: amdgpu temp: 32.0 C
Fan Speeds (RPM): N/A
Processes: 308 Uptime: 3m wakeups: 346 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1069 lib: 300 Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.11
