Reboot notice
https://archlinux.org/packages/extra/x86_64/libnotify/
Last Updated: 2025-02-22 01:07 UTC
I suppose you could test by downgrading this package and install a kernel or something?
yes only a startpoint to investigate there is no log aside from what i was catching on journal.
But yes if its a change on libnotify package downgrading should remove the issue.
there you have it…
I just installed this:
: Searching databases for updates...
 -> Orphan (unmaintained) AUR Packages: vanilla-backgrounds
:: 7 packages to upgrade/install.
7  core/diffutils    3.10-1   -> 3.11-1
6  core/kmod         33-3     -> 34-1
5  core/libnghttp3   1.7.0-1  -> 1.8.0-1
4  core/pcre2        10.44-1  -> 10.45-1
3  core/which        2.21-6   -> 2.22-1
2  core/zstd         1.5.6-1  -> 1.5.7-2
1  aur/freetube-bin  0.23.1-1 -> 0.23.2-1
and output ended with
(1/4) Arming ConditionNeedsUpdate...
(2/4) Updating icon theme caches...
(3/4) Checking which packages need to be rebuilt
(4/4) Updating the desktop file MIME type cache...
no reboot info or bubble. but those core elements don’t need a reboot I assume.
Thanks guys for investigating this issue!
Downgrading libnotify helps with this.
Nice joint effort.
Looks like this wasn’t the only problem.
Now emacs needs package libgccjit.
More issues may be coming…
emacs was updated today.
Happy to inform you all that eos-bash-shared version 25.2.11-1 solves the issue with libnotify 0.8.4-1.
That means you don’t have to downgrade libnotify anymore.
If interested, see this: https://gitlab.gnome.org/GNOME/libnotify/-/issues/54
You are the best!
@manuel
The notification to reboot came back. I just updated and it popped up.
[2025-02-25T15:52:09-0500] [ALPM] transaction started
[2025-02-25T15:52:09-0500] [ALPM] upgraded eos-bash-shared (25.2.10-1 -> 25.2.11-1)
[2025-02-25T15:52:09-0500] [ALPM] upgraded libavif (1.1.1-2 -> 1.2.0-1)
[2025-02-25T15:52:09-0500] [ALPM] upgraded xorg-server-common (21.1.15-1 -> 21.1.16-1)
[2025-02-25T15:52:09-0500] [ALPM] upgraded xorg-server (21.1.15-1 -> 21.1.16-1)
[2025-02-25T15:52:09-0500] [ALPM] upgraded xorg-xwayland (24.1.5-1 -> 24.1.6-1)
[2025-02-25T15:52:09-0500] [ALPM] transaction completed
And @sammiev
Thanks for confirming! :smiley:
Is it a change in the eos-bash-shared? Or another package?
Yes, eos-bash-shared because it shares code to some other EndeavourOS apps.
The notification call is there.
notify-send (of package libnotify from upstream) no more accepted value zero for the --expire-time parameter which it should have simply ignored for this type of notification, but instead stopped notifying.
got the balloon…don’t remember say 'inform user to reboot; in the code at the end of terminal output. Is this still an issue or did I miss it?
Seeing as how Arch Linux gives this advice:
" Upgrades are typically not applied to existing processes. You must restart processes to fully apply the upgrade. "
https://wiki.archlinux.org/title/System_maintenance#Restart_or_reboot_after_upgrades
Is a reboot notifier really needed? I say this not to take anything away from the work manuel puts in, especially tracking down the reason:
