I understand that EOS uses:
pipewire-alsa (installed)
pipewire-pulse (installed)
pipewire-jack
problem statement : the hardware (MSI Cubi) has a Realtek ALC233 but no microphone input from 3,5 mm jack is received. AlsaMixer
shows sound levels up.
The headset used for testing is not a problem since it works on a desktop with an ALC897 just fine.
To go through USB is always an option but not intended.
Any proposals on how to debug? Thanks.
have you pipewire-media-session installed ?
So, I tried just now - it removed wireplumber
, no change.
Do you have an audio mixer such as pauvcontrol
? If so what does it say for the realtek soundcard configuration?
ng0177
May 26, 2022, 10:24am
5
pipewire
not pulseaudio
is the default
ng0177
May 26, 2022, 10:26am
6
Which is the difference between:
vs wireplumber
(default)
ng0177
May 26, 2022, 10:29am
7
solution: the extension cable needs TRRS w/ 4 ports including microphone channel, then everything works as expected.
Should I revert to wireplumber
pebcak
May 26, 2022, 10:36am
8
If you have working Audio with wireplumber, then I would say go for it.
You can also stay with pipewire-media-session
but it is recommended to use wireplumber
as pipewire-media-session
is/was only there to start creating Session managers like wireplumber
https://discovery.endeavouros.com/audio/pipewire/2021/09/
system
Closed
May 28, 2022, 10:37am
9
