Is there a way(I’m sure there is lol) using rate-mirrors-bin to sort by only countries that i want using only https, https update servers more secure?
1.United States
2.United Kingdom
3.Germany
4.France
5.Canada
Thanks!
1.United States
2.United Kingdom
3.Germany
4.France
5.Canada
Thanks!
A few things:
rate-mirrors --protocol=https --protocol=http arch
Thank you, much appreciated.
@dalto would this be correct?
rate-mirrors --protocol=https arch | sudo tee /etc/pacman.d/mirrorlist
@dalto That indeed worked, I used
This is now at the bottom of my mirror list
# FINISHED AT: 2021-11-25 14:45:21.908793966 -05:00
Server = https://mirrors.kamey.tk/archlinux/$repo/os/$arch
Server = https://arch.mirror.constant.com/$repo/os/$arch
Server = https://mirror.sergal.org/archlinux/$repo/os/$arch
Server = https://mirror.csclub.uwaterloo.ca/archlinux/$repo/os/$arch
Server = https://america.mirror.pkgbuild.com/$repo/os/$arch
Server = https://arch.mirror.jsc.mx/$repo/os/$arch
Server = https://mirror.cyberbits.eu/archlinux/$repo/os/$arch
Server = https://mirror.f4st.host/archlinux/$repo/os/$arch
Server = https://archlinux.mailtunnel.eu/$repo/os/$arch
Server = https://mirror.ams1.nl.leaseweb.net/archlinux/$repo/os/$arch
Server = https://archlinux.uk.mirror.allworldit.com/archlinux/$repo/os/$arch
Server = https://mirror.smith.geek.nz/archlinux/$repo/os/$arch
Server = https://mirrors.cat.net/archlinux/$repo/os/$arch
Server = https://mirrors.melbourne.co.uk/archlinux/$repo/os/$arch
Server = https://archlinux.thaller.ws/$repo/os/$arch
Server = https://ftp.jaist.ac.jp/pub/Linux/ArchLinux/$repo/os/$arch
Thanks again!
A convenience of rate-mirrors
over reflector
is that it will usually give you a great list of mirrors without any options. Typically it is sufficient to just run it with:
rate-mirrors arch
and redirect its standard output to your mirror list file (for example, using sudo tee
Regarding http vs. https protocols, https is encrypted and thus any information send through it cannot be intercepted by a third party. In practice, however, I don’t think that makes a lot of difference, since pacman
typically checks signatures of packages before installing them (at least it does for the official repos). In practice, I don’t think an attacker could abuse the http protocol to serve you a modified version of a package. The only security concern that comes to my mind is that http traffic can easily be monitored, so a malicious third party could make logs of packages you’re updating and keep a profile of you.
That said, http mirrors tend to be much faster than https mirrors.
Perhaps I am wrong about this, in which case, I would appreciate someone correcting me.
Thanks for sharing that info.
