There are no hackers after you. The laptop is simply seeing no battery.
Andrew you are being paranoid now. If you want and need to, put black tape over the webcam.
Unfortunately not that model.
No , i wasnt saying being hack nor being paranoid. You miss understood me.
My main point here is, LED indicator light is not Hardwired to the device it is indicatingā¦ but rather, they are all switched on and off being mean of software, hence hacker can take the opportunity to do their spying without user knowing.
Indeed i saw the news on tv that hacker has the technology to spy on you or hear what you saying without you even noticed.
By the way, i do sometime cover my webcam (just follow what Bill gate would do) Better safe than sorry.
Err, i think this is no longer an issue, since āi really believeā the color is according to the Graphic card used (nvidia or build inā¦ since my laptop is hybrid graphic card).
$ inxi -Fxxxa --no-host
System: Kernel: 5.8.13-arch1-1 x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=e243610f-aeef-4cd0-8dea-3456638f11f6 rw loglevel=3 nowatchdog
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: EndeavourOS
Machine: Type: Desktop System: Micro-Star product: GP60 2QE v: REV:1.0 serial: <superuser/root required>
Mobo: Micro-Star model: MS-16GH v: REV:1.0 serial: <superuser/root required> BIOS: American Megatrends
v: E16GHIMS.10H date: 12/25/2014
CPU: Info: Dual Core model: Intel Core i5-4210H bits: 64 type: MT MCP arch: Haswell family: 6 model-id: 3C (60)
stepping: 3 microcode: 28 L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23153
Speed: 798 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 819 2: 863 3: 887 4: 909
Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Micro-Star MSI driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:0416
Device-2: NVIDIA GM108M [GeForce 940M] vendor: Micro-Star MSI driver: nvidia v: 455.23.04
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1347
Device-3: Acer MSI Integrated Webcam type: USB driver: uvcvideo bus ID: 1-1.4:4 chip ID: 5986:014c
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel,nvidia unloaded: fbdev,modesetting,vesa
alternate: nouveau,nv display ID: :0 screens: 1
Screen-1: 0 s-res: 1921x2160 s-dpi: 96 s-size: 506x570mm (19.9x22.4") s-diag: 762mm (30")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
Monitor-2: HDMI1 res: 1920x1080 hz: 60 dpi: 305 size: 160x90mm (6.3x3.5") diag: 184mm (7.2")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2) v: 4.5 Mesa 20.1.8 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 00:03.0 chip ID: 8086:0c0c
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:8c20
Sound Server: ALSA v: k5.8.13-arch1-1
Network: Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet vendor: Micro-Star MSI driver: alx v: kernel port: d000
bus ID: 03:00.0 chip ID: 1969:e091
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: 44:8a:5b:f2:c7:61
Device-2: Intel Wireless 3160 driver: iwlwifi v: kernel port: d000 bus ID: 05:00.0 chip ID: 8086:08b3
IF: wlan0 state: down mac: de:67:a9:4f:28:43
Drives: Local Storage: total: 1.36 TiB used: 429.76 GiB (30.8%)
ID-1: /dev/sda vendor: Western Digital model: WD5000LPVX-22V0TT0 size: 465.76 GiB block size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm serial: WD-WXB1AC4FCAS2 rev: 1A01 scheme: MBR
ID-2: /dev/sdb vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB block size: physical: 4096 B logical: 512 B
speed: 3.0 Gb/s rotation: 5400 rpm serial: Y3CMT7EGT rev: 1U scheme: MBR
Partition: ID-1: / raw size: 78.97 GiB size: 77.23 GiB (97.80%) used: 19.52 GiB (25.3%) fs: ext4 dev: /dev/sdb1
ID-2: /home raw size: 852.54 GiB size: 838.16 GiB (98.31%) used: 58.12 GiB (6.9%) fs: ext4 dev: /dev/sdb2
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 41.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info: Processes: 200 Uptime: 16h 07m Memory: 15.56 GiB used: 2.46 GiB (15.8%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1070 lib: 256 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.07
Just wanted to look at your Graphics because it looks like you do have hybrid Intel and Nvidia. So it looks like you installed the Nvidia drivers. Did you do this on the install? You have the Nvidia 940M mobile with Intel onboard graphics i915. (HD 4600) So looks like you are using KDE plasma. Maybe if you have it set up on optimus & you can switch graphics between Intel and Nvidia. That may change the power light. I assume you not gaming. The Nvidia is dedicated Graphics. Did you try TLP?
I canāt remember i installed Nvidia or not during os installation, but i have not yet (no time yet) try to install optimus or nvidia (i do have a thread in forum, that someone told me to install optimus, i still have the webpage to that, but i really have no time to install it yet). I also have not install TLP yet.
I was wonder why should i install advance power management ? since i have no power issue, thatās why i was hesitating to try it. also because i have no time to do itā¦ Also because i have not finish with timeshiftā¦ Until i get timeshift done, i halt all packages installation. just to be safe.
Sounds like too much multitasking!
Ya, also lack of time and knowledge. It took so long for me to read and understand all these technical thing, because i canāt rely on spoonfeeding (nobody on forum like it), but sometime i really lack of time, to solve a tiny issue, i have to browse internet and read about it, by the time i am halfway, something happened againā¦ hence sometime i just want to get it done, donāt want to be expert in itā¦ too much stuff that are not tune rightly on this laptopā¦ i have not even install input method, because i need to type asian language sometime, i have not install confirmed my video card, i have not tune my wifi indicator led, and many moreā¦ I think that all these are too much for a person who have being using windows for the most of his lifeā¦
Can you spoonfeed me the command to check if i am running on nvidia, and if optimus is install and configured ā¦etc ? so i can have 1 less issue to deal with. pls
Btw, i do have TLP installed. Maybe preinstalled. I donāt recall i installed it.
$ pacman -Ss tlp
community/tlp 1.3.1-2 [installed]
Linux Advanced Power Management
community/tlp-rdw 1.3.1-2
Linux Advanced Power Management - Radio Device Wizard
The command you posted already shows you have Nvidia installed and itās a hybrid graphics.
Yes, Nvidia hardware is phyiscally installed from inxi output, but how do i know if the driver for Nvidia is installed ? or it is maybe just run base on default general driver which is not optimized for nvidia. thatās what i want to know.
how to know if āoptimusā is installed and configured rightly for the nvidia card ?
$ locate optimus
/home/timeshift/snapshots/2020-10-05_23-47-45/localhost/usr/share/doc/nvidia/html/optimus.html
/home/timeshift/snapshots/2020-10-05_23-47-45/localhost/usr/share/media-player-info/lg_ally_optimus-one_vortex.mpi
/home/timeshift/snapshots/2020-10-05_23-47-45/localhost/usr/share/media-player-info/lg_optimus-one-p500.mpi
/home/timeshift/snapshots/2020-10-05_23-47-45/localhost/usr/share/media-player-info/lg_optimus-s.mpi
/home/timeshift/snapshots/2020-10-06_05-52-08/localhost/usr/share/doc/nvidia/html/optimus.html
/home/timeshift/snapshots/2020-10-06_05-52-08/localhost/usr/share/media-player-info/lg_ally_optimus-one_vortex.mpi
/home/timeshift/snapshots/2020-10-06_05-52-08/localhost/usr/share/media-player-info/lg_optimus-one-p500.mpi
/home/timeshift/snapshots/2020-10-06_05-52-08/localhost/usr/share/media-player-info/lg_optimus-s.mpi
/timeshift/snapshots/2020-10-06_06-49-33/localhost/usr/share/doc/nvidia/html/optimus.html
/timeshift/snapshots/2020-10-06_06-49-33/localhost/usr/share/media-player-info/lg_ally_optimus-one_vortex.mpi
/timeshift/snapshots/2020-10-06_06-49-33/localhost/usr/share/media-player-info/lg_optimus-one-p500.mpi
/timeshift/snapshots/2020-10-06_06-49-33/localhost/usr/share/media-player-info/lg_optimus-s.mpi
Itās right in the output of the command.
Edit: Just so you understand this. The Intel is automatically using the kernel module and the proprietary Nvidia drivers are installed. version 455.23.04
This has nothing to do with Optimus-manager for the Hybrid Graphics so donāt even go there!
I have saw the graphics: Device-2 (correct me if i am wrong) Nvidiaā¦ In windows os, there is also software that can list out what hardware you have on system. but that does not mean the driver to the hardware is installed and running without isue ? Thatās what i puzzled hereā¦ i saw the Nvidia, but i didnāt see any statement that shows signed Optimus is installed and is running
Oh
I really think at this point i would just stay with what you have because everything is working. There are some things with switching back & forth between the dedicated graphics such as losing your work unless you have it saved first. Hybrid graphics are really designed to move to the dedicated graphics for gaming or work that requires a better graphics card than what the Intel provides.
Iām not so sure you should worry about these things right now. Better that you have a system running and no problems.
Since we are here already, can you please enlighten me in regarding to this 2. I am not sure what they areā¦ are Nvidia optimus a driver or software for nvidia card ? and is Bumblebee a software ? if not what are they ? what do they do for my laptop ? i am really hazy hereā¦
NVIDIA Optimus is a technology that allows an Intel integrated GPU and discrete NVIDIA GPU to be built into and accessed by a laptop.
Bumblebee is an effort to make NVIDIA Optimus enabled laptops work in GNU/Linux systems. Such feature involves two graphics cards with two different power consumption profiles plugged in a layered way sharing a single framebuffer.
This is really like having a farrari but i can only drive volkwagenā¦ if i can switch to farrari i would love to just stick with farrari, because i alway use laptop plugged in.
If you want to try optimus-manager it will be your doing because if things go wrong i canāt help you and this is where the problem will start. I just think it might be too advanced for you at this stage.
