rainbowstream gives more or less the same result for installation with each of three python-twitter contributions:
mehdi@mehdi-80qr ~> rainbowstream
File "/usr/bin/rainbowstream", line 33, in <module>
sys.exit(load_entry_point('rainbowstream==1.5.2', 'console_scripts', 'rainbowstream')())
File "/usr/bin/rainbowstream", line 25, in importlib_load_entry_point
return next(matches).load()
File "/usr/lib/python3.9/importlib/metadata.py", line 77, in load
module = import_module(match.group('module'))
File "/usr/lib/python3.9/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 850, in exec_module
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
File "/usr/lib/python3.9/site-packages/rainbowstream/rainbow.py", line 11, in <module>
import pkg_resources
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3243, in <module>
def _initialize_master_working_set():
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3226, in _call_aside
f(*args, **kwargs)
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3255, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 568, in _build_master
ws.require(__requires__)
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 886, in require
needed = self.resolve(parse_requirements(requirements))
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 772, in resolve
raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'twitter' distribution was not found and is required by rainbowstream
an idea ? can someone repeat?
