I updated the system last Friday and my pc stopped recognizing to my ethernet.
After 3 hours trying to fix it I found that r8169 module didnt load so i used modprobe to load it and it worked fine,but when i reboot the system i need to manually load the module again.
How can i load it automatically
Did you have the r8168 package installed previously? If so, wtach out for a file
r8168.conf
in /usr/lib/modprobe.d or /etc/modprobe.d.
This conf file is blacklisting the r8169 modul. Just delete the r8168 package and the conf file if you are good with the r8169 modul.
did not work
