Hi,
I have no ethernet on my EOS i3
I do have ethernet when booted into Manjaro, Archbang or win10 on same computer with same ethernet cable
Wifi is working
I have the following results:
$ yay r8168
5 aur/r8168-pf 8.045.08-1 (+0 0.00) (Orphaned)
A kernel module for Realtek 8168 network cards(pf kernel)
4 aur/r8168-ck 8.048.03-1 (+1 0.00) (Orphaned)
A kernel module for Realtek 8168 network cards (linux-ck)
3 aur/r8168-dkms 8.049.02-1 (+19 1.12)
A kernel module for Realtek 8168 network cards (DKMS version)
2 community/r8168-lts 8.049.02-41 (708.2 KiB 705.8 KiB) (Installed)
A kernel module for Realtek 8168 network cards for linux-lts
1 community/r8168 8.049.02-46 (72.2 KiB 69.8 KiB) (Installed)
$ uname -r
5.10.88-2-lts
sudo modprobe r8168
modprobe: FATAL: Module r8168 not found in directory /lib/modules/5.10.88-2-lts
$ inxi -FAZ --no-host | eos-sendlog
% Total % Received % Xferd Average Speed Time Time Time Current
100 2333 0 24 100 2309 37 3608 --:--:-- --:--:-- --:--:-- 3651
https://clbin.com/cHzFD
$ sudo dmesg | grep r81
[sudo] password for leigh:
[ 0.054153] percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u524288
[ 0.054164] pcpu-alloc: s225280 r8192 d28672 u524288 alloc=1*2097152
With wifi disabled
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (6) Could not resolve host: clbin.com
Also prvide output of sudo lsmod | grep r81 please
Looks like the driver is not loaded and I dont have the knowledge why that happened. I think you can load it manually like so: sudo nano /etc/modprobe.d/ethernet.conf
Nearly!
That didnt work but when took the blacklist r1869 line out of /usr/lib/modprobe.d/r8168-lts.conf it worked!
Thanks!
Before I mark as solved - what did I just do?
Did I swap from r8168 to 8169 drivers?
Can I now uninstall r8168 and r8168-lts?
Why did I have that problem - is there a problem with the r8168 drivers?
