Can I run EndeavourOS with RX 5700 XT?
I tried it before on GTX 970 and worked great but after switching to RX 5700 I couldn’t enter the DE.
hello,
our OS is already installed on your pc, but what I understood. you have changed your graphics card: from NVIDIA to AND.tu can do: tty2 an inxi -F
to know which driver is installed
I had it installed. Right now I have only windows 10.
Hello @athov I don’t know what your hardware specs are such as your motherboard. You would need to check your Uefi Bios as it may require updating. It is my understanding The card does work on Arch with 5.3 with a little effort. Here is some information to read that may help.
So it’s the kernel I was on 5.1 guess I will wait for few months.
Specs are:
MB: MSI B450 Tomahawk
CPU: Ryzen 5 2600
BIOS: 7C02v17
Did something new get discovered with this GPU so far? I myself have the non xt version and struggle with complete freezings of the pc and frame drops in games to less than 10 for seconds.
