I took a look at my pacman.conf
(it is probably still in the same state as it was after the new installation). I noticed a difference in the commented out lines. I don’t know anything about programming, so my question is: In some commented out lines, the #
is at the beginning of the line (which, as I understand it, comments out the line) and then there is a space
before the content of the line begins. For other lines, the #
is immediately followed by the content, without a space
in between. What is the difference, what does it do? I know that a space
acts as a separator, but what for after the #
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir = /
#DBPath = /var/lib/pacman/
#CacheDir = /var/cache/pacman/pkg/
#LogFile = /var/log/pacman.log
#GPGDir = /etc/pacman.d/gnupg/
#HookDir = /etc/pacman.d/hooks/
HoldPkg = pacman glibc
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta = 0.7
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
Color
ILoveCandy
#NoProgressBar
#CheckSpace
VerbosePkgLists
DisableDownloadTimeout
ParallelDownloads = 5
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
and so on …
Please enlighten me as to what is correct.
