There is a setting in grub.conf that controls resolution of the grub menu. It’s set to auto by default but can be set to any resolution your video card can display. I set mine to 1024x768 with auto as a fallback. I’m on my cellphone now, but when I get home I can post the correct setting and process.
I do not recommend using Grub Customizer. It has to work with too many systems to be aware of all the nuances and be aware of multiple updates. I’m reminded of this quote from the Manjaro forums " … it may work fine … until it doesn’t".
For the most part, I use this tool in the same way I use most graphical system tools (e.g. pamac).
I use it to help sort out what I want to do. Then, I’ll do the final implementation by the command line. That way, I have better control of the process.
As promised here’s the way I set the grub resolution.
GRUB_GFXMODE=auto was defaulting to a very low resolution and would not display a complete menu line. To see which resolutions a graphics card will display, type c for a grub command line during boot at the grub menu and then type vbeinfo.
grub> vbeinfo
This will display the resolutions. (many) I chose 1024x768.
Edit /etc/default/grub and modify the line
GRUB_GFXMODE=auto
to
GRUB_GFXMODE=1024x768,auto
Save grub and then update grub.cfg with
and reboot.
This tells grub to try1024x768 first and if that fails then it tries auto.
Now I have a 1024x768 initial display resolution for the grub menu.
Funny, I duo boot Manjaro and Endeavour, then use Grub Customizer to sort it out. It really depends upon which OS you last installed as to which takes precedent. I use it to reorder grub after installing linux-lts in Endeavour otherwise it opens with the LTS.
You are correct, seems like the latest kernel is added at the top of the grub list. When installing LTS the result is:
0 LTS Kernel
1 LTS Fallback
2 Current Kernel
3 Current Fallback
Note: Numbering of GRUB menu entries start with 0.
I just edited grub to make Current Kernel the default.
Backup the current grub:
sudo cp /etc/default/grub /etc/default/grub.bak
Then edit grub:
sudo nano /etc/default/grub
Set the default kernel by commenting out the current “GRUB_DEFAULT=” line and changing the “GRUB_DEFAULT=” line to match the kernel you wish to boot:
#GRUB_DEFAULT=saved
GRUB_DEFAULT=“1>2”
The 1 above points to the grub Advanced menu, and the 2 points to the position of the kernel in the boot list. In this case the thid entry. It is also necessary to include the above numbers in quotes. Note: GRUB_DEFAULT=2 also works
With Grub Customizer it is a simple matter to highlight and move up the default kernel and then save without all that work in Terminal. You just need to read the manual, which is very thorough.
It’s not about ease of use. It’s about knowing what is being modified in grub and avoiding surprises. You’re comfortable using Grub Customizer. I’m not. It’s good that we have choices.
