Qbittorrent crashes after system update
Anyone has any clue or how to fix? Thank you.
Run it from terminal and post the output when it crashes.
Also:
For this case, which command should I run or which categories should I check on the EOS log tools GUI? Thanks.
/usr/bin/qbittorrent
And after the crash:
journalctl | grep qbittorrent
Also, check in /var/log/pacman.log to see you can see something related to this application got updated, like its dependencies etc.
Hello everyone.
Same issue. Downgraded libtorrent-rasterbar 1:2.0.11-5 → 1:2.0.11-4, problem solved
Looks like they know about it so I suppose a new update will son be in the repos:
@apachecai @casper1975
5.1.2-2 is in extra-testing. This will solve the issue. Keep your system updated as usual.
https://archlinux.org/packages/?q=qbittorrent
Its mostly covered above but here is the qbit open issue..
pacman -Ss qbittorrent
extra/qbittorrent 5.1.2-2
It’ in extra now.
