Pulseeffects sometimes mutes microphone
When I try to use pulseeffects effect on the microphone, it sometimes results in muted mic-audio.
Somtimes, a restart or a reboot solves the problem. I am under the impression, that I do something that breaks it and fixes it. Like it’s working for a week, and then not working for a week, etc. However, I have no clue, what it is.
I think, the problem is, that pulseeffects source somehow doesn’t generate audio.
journalctl:
Mai 15 15:19:01 elendil-pc pipewire[2411]: impl-core 0x558b4a723690: error -5 for resource 3: node_set_param(Spa:Enum:ParamId:PortConfig) failed: Eingabe-/Ausgabefehler
Mai 15 15:19:01 elendil-pc pipewire[2411]: client-node 0x558b4a91a040: error seq:55 -5 (node_set_param(Spa:Enum:ParamId:PortConfig) failed: Eingabe-/Ausgabefehler)
Mai 15 15:19:01 elendil-pc pipewire[2411]: client-node 0x558b4a91a040: error seq:57 -5 (node_set_param(Spa:Enum:ParamId:PortConfig) failed: Eingabe-/Ausgabefehler)
Eingabe-/Ausgabefehler is I/O-Error
I found a workaround that temporarily fixes the issue.
  1. Start pulseeffects
  2. Start an application that uses the microphone
  3. systemctl --user restart pipewire
  4. restart the application that uses the microphone
Edit: I was wrong. It does not work. The audio was actually not routed through pulseeffects, even though it claimed it was.
Pulseeffects-legacy, good until they fix all the issues. :slightly_smiling_face: :upside_down_face:
