When starting a system update, in the Welcome menu, instead of some symbols, only rectangles are displayed. Is it possible to fix it?
change the monospace font
Sorry, I’m a newbie. Tell me how to do it
Hopefully someone who uses gnome can give you more specific instructions. I can only tell you to go to the system settings in gnome and look for something like fonts
Maybe the problem is related to your default font.
Try this:
uxterm -fa mono:size=16
(I mean, for example, run it with Alt+F2)
Thank you very much. Played with the settings in fonts and everything is fine
