Problems with the light of the monitors
Recently after an update, my monitors are unable to maintain the light setting I put in. If I put it at 60% for example, if I restart the computer, turn it off, or turn off the monitors when I turn it back on is at 100% light. Would it be a problem relating to system updates? Has anyone experienced this?
what desktop manager you are using
Are you using an AMD GPU? This might be releated?
Arch Wiki > Backlight > 6.9 Backlight is always at full brightness after a reboot with amdgpu driver
Yes, I have a Ryzen 5600X, and my graphics card is an RTX 3060.
Im using XFCE.
laptop or desktop
