Problems with the Konsole
Hi everyone, I have a problem with the terminal in KDE with ‘Konsole’ - when I use the shortcut CTRL+ALT+T, Konsole opens with root user. How can I fix this?
You are the second person to report this in the last few hours but I am not seeing here.
I am not sure I have any obvious suggestions without being able to reproduce it.
:thinking:
What about when starting konsole from the menu?
All good from there (menu)
I have noticed that dolphin (shortcut) also opens with the root user. Weird!
Me neither. what is the dolphin shortcut ?
Pudge
meta+e
here also :roll_eyes:
Both Dolphin and Konsole keyboard shortcuts work as expected here :thinking:
Maybe the problem would be with keyboard shortcut using root, it opens any app in root.
You need to find where is bad shortcut config.
Edit://
I doubt which installed package caused this issue.
Check paclog to see what package was updated or installed. For example:
$ paclog --after=2023-05-22
or if you have btrfs snapshots for root subvolume, you can compare old snapshot and the current snapshot to detect which package or config is bad.
Works as expected here also. :thinking:
Same (runs as my logged-in user).
The first thing I would ask would be if you do shenanigans and have ran konsole and dolphin as root (which you shouldn’t do). Dunno, but that’s just what I feel would be the first question.
My system is behaving normally, although it’s heavily customised. Anything requiring root access still requires a password though, indicating security. If people are getting root access without a password, eek! This is a KDE system I am running, just to clarify.
