Problems with electron9 9.4.4-1
Fair enough, but my issue is not explicitly the time it takes to compile but the fact that it compiles a half dozen apps that you aren’t installing or have installed already. The compilation bloat is completely the opposite of the Linux philosophy.
The solution is really simple, though, as you yourself have noticed: don’t use it!
It’s not as if there are no alternatives…
I try to install popsicle-git now. I will let you know how’s it going.
Works fine and i give you all a big thank you for your help.
