Has anyone else found that they’ve been unable to put their computer to sleep since recent kernel updates? I think the problem started around kernel version 5.12.12. I’m using the Linux Zen kernel.
I’m not sure where to look for clues.
My output from inxi --admin --verbosity=7 --filter --no-host --width
is:
Kernel: 5.12.13-zen1-2-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=f4a38316-ac59-4e5c-a8b1-8eaf4671e28f rw rootflags=subvol=@ quiet
loglevel=3 nowatchdog mitigations=off
Console: tty pts/1 wm: kwin_x11 DM: SDDM Distro: EndeavourOS
base: Arch Linux
Type: Desktop System: Intel Client Systems product: NUC8i7HVK v: J71485-504
serial: <filter> Chassis: Intel Corporation type: 3 v: 2.0 serial: N/A
Mobo: Intel model: NUC8i7HVB v: J68196-504 serial: <filter> UEFI: Intel
v: HNKBLi70.86A.0066.2021.0310.1823 date: 03/10/2021
Battery:
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Memory:
RAM: total: 31.27 GiB used: 3.06 GiB (9.8%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: ChannelA-DIMM0 size: 16 GiB speed: 3200 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: Micron part-no: 16ATF2G64HZ-3G2E1
serial: <filter>
Device-2: ChannelB-DIMM0 size: 16 GiB speed: 3200 MT/s type: DDR4
serial: <filter>
Info: Quad Core model: Intel Core i7-8809G socket: BGA1440 (U3E1)
note: check bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 9E (158) stepping: 9 microcode: EA cache: L2: 8 MiB
bogomips: 49599
Speed: 870 MHz min/max: 800/8300 MHz base/boost: 3100/4100 volts: 0.9 V
ext-clock: 100 MHz Core speeds (MHz): 1: 870 2: 881 3: 900 4: 900 5: 900
6: 900 7: 900 8: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est
f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spec_store_bypass status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
Type: srbds status: Vulnerable
Device-1: Intel HD Graphics 630 driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0380
Device-2: AMD Polaris 22 XT [Radeon RX Vega M GH] vendor: Intel
driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:694c class-ID: 0300
Display: server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu,ati,intel unloaded: fbdev,modesetting,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: DisplayPort-2 res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
Monitor-2: DisplayPort-3 res: 1920x1080 hz: 60 dpi: 93
OpenGL: renderer: AMD VEGAM (DRM 3.40.0 5.12.13-zen1-2-zen LLVM 12.0.0)
v: 4.6 Mesa 21.1.3 direct render: Yes
Device-1: Intel CM238 HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Device-2: AMD Polaris 22 HDMI Audio vendor: Intel driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 1002:ab08 class-ID: 0403
Device-3: Logitech Logitech StreamCam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 6-1:2
chip-ID: 046d:0893 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.12.13-zen1-2-zen running: yes
Sound Server-2: JACK v: 0.125.0 running: no
Sound Server-3: PulseAudio v: 14.2 running: yes
Sound Server-4: PipeWire v: 0.3.31 running: no
Device-1: Intel Ethernet I219-LM driver: e1000e v: kernel port: f040
bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
IF: eno1 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global
broadcast: <filter>
IP v6: <filter> type: noprefixroute scope: link
Device-2: Intel I210 Gigabit Network driver: igb v: kernel port: b000
bus-ID: 05:00.0 chip-ID: 8086:157b class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-3: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: b000
bus-ID: 06:00.0 chip-ID: 8086:24fd class-ID: 0280
WAN IP: <filter>
Bluetooth:
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8
bus-ID: 1-9:3 chip-ID: 8087:0a2b class-ID: e001
Report: This feature requires one of these tools: hciconfig/bt-adapter
Logical:
Message: No LVM data was found.
RAID:
Message: No RAID data was found.
Local Storage: total: 1.86 TiB used: 613.72 GiB (32.2%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 970 PRO 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 1B2QEXP7 temp: 64 Celsius C
scheme: GPT
SMART: yes health: PASSED on: 191d 19h cycles: 853
read-units: 13,804,946 [7.06 TB] written-units: 21,068,965 [10.7 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
lanes: 4 rotation: SSD serial: <filter> rev: SS0411B temp: 45 Celsius C
scheme: GPT
SMART: yes health: PASSED on: 1y 90d 17h cycles: 12
read-units: 5,649,300 [2.89 TB] written-units: 2,069,899 [1.05 TB]
Message: No Optical or Floppy data was found.
ID-1: / raw-size: 953.37 GiB size: 953.37 GiB (100.00%)
used: 228.55 GiB (24.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:4 label: N/A uuid: f4a38316-ac59-4e5c-a8b1-8eaf4671e28f
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 560 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:3 label: BOOT uuid: 84C5-E4B4
ID-3: /data raw-size: 953.87 GiB size: 937.9 GiB (98.33%)
used: 385.17 GiB (41.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p1
maj-min: 259:1 label: data uuid: 6972938f-a9bb-4fe2-ae95-516b0026a3f5
ID-4: /home raw-size: 953.37 GiB size: 953.37 GiB (100.00%)
ID-5: /run/timeshift/backup raw-size: 953.37 GiB size: 953.37 GiB (100.00%)
ID-6: /swap raw-size: 953.37 GiB size: 953.37 GiB (100.00%)
ID-7: /var/cache/pacman/pkg raw-size: 953.37 GiB size: 953.37 GiB (100.00%)
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 29.8 GiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
Unmounted:
Message: No Unmounted partitions found.
USB:
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-3:2 info: Logitech DELL Laser Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 98mA chip-ID: 046d:c063 class-ID: 0301
Device-2: 1-9:3 info: Intel Bluetooth wireless interface type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA
Device-3: 1-10:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s
chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 6-1:2 info: Logitech Logitech StreamCam type: Video,Audio,HID
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 6 rev: 3.2
speed: 5 Gb/s power: 896mA chip-ID: 046d:0893 class-ID: 0300
serial: <filter>
System Temperatures: cpu: 71.0 C mobo: 29.8 C gpu: amdgpu temp: 53.0 C
Fan Speeds (RPM): N/A
Processes: 278 Uptime: 29m wakeups: 18 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 alt: 10/9 clang: 12.0.0 Packages: pacman: 1570
lib: 345 Shell: Zsh (sudo) v: 5.8 running-in: konsole inxi: 3.3.03
