Ok, it’s perfect, I don’t use firefox, that’s why I said it;)
wget 'https://forum.endeavouros.com/t/problems-installing-in-uefi-calamares/2896'
shell=zsh
No length set. ![]()
~/endeavour >>> wget 'https://forum.endeavouros.com/t/problems-installing-in-uefi-calamares/'
--2020-01-03 21:32:02-- https://forum.endeavouros.com/t/problems-installing-in-uefi-calamares/
CA-Zertifikat »/etc/ssl/certs/ca-certificates.crt« wurde geladen
Auflösen des Hostnamens forum.endeavouros.com (forum.endeavouros.com)… 157.230.31.2
Verbindungsaufbau zu forum.endeavouros.com (forum.endeavouros.com)|157.230.31.2|:443 … verbunden.
HTTP-Anforderung gesendet, auf Antwort wird gewartet … 301 Moved Permanently
Platz: https://forum.endeavouros.com/t/problems-installing-in-uefi-calamares/2896 [folgend]
--2020-01-03 21:32:02-- https://forum.endeavouros.com/t/problems-installing-in-uefi-calamares/2896
Wiederverwendung der bestehenden Verbindung zu forum.endeavouros.com:443.
HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK
Länge: nicht spezifiziert [text/html]
Wird in »index.html« gespeichert.
index.html [ <=> ] 60,34K --.-KB/s in 0,02s
2020-01-03 21:32:03 (3,01 MB/s) - »index.html« gespeichert [61793]
If you create a bookmark to this page in your browser, would that help?
Or simply copy this page address to a text file and save it?
Or copy/paste this page to e.g. in LibreOffice Writer document?
Well yes, it looks like this is the only solution … i want to have some documents in an exterior memory, in case that something happen with the OS.
You can use like zim and make a personal wiki and those can vbe saved
Did you use this address:
I’m tired i will comeback tomorrow. Thanks everybody.
mostly all browsers provide a fileoption to save webpages
In web page
Ctrl + a
Ctrl + c
Open LibreOffice, new textfile, then
Ctrl + v
save as .odt
Problem, all flags (Countries) are very big
Extrude odt file with engrampa and delete all flags
[sgs@mx odt]$ ls -la /home/sgs/odt
insgesamt 176K
drwxr-xr-x 6 sgs sgs 4,0K 03.01.2020 22:09 ./
drwx------ 70 sgs sgs 4,0K 03.01.2020 22:14 ../
drwxr-xr-x 11 sgs sgs 4,0K 03.01.2020 22:09 Configurations2/
drwxr-xr-x 2 sgs sgs 4,0K 03.01.2020 22:09 META-INF/
drwxr-xr-x 2 sgs sgs 4,0K 03.01.2020 22:09 Pictures/
drwxr-xr-x 2 sgs sgs 4,0K 03.01.2020 22:09 Thumbnails/
-rw-r--r-- 1 sgs sgs 104K 03.01.2020 21:09 content.xml
-rw-r--r-- 1 sgs sgs 225 03.01.2020 21:09 layout-cache
-rw-r--r-- 1 sgs sgs 899 03.01.2020 21:09 manifest.rdf
-rw-r--r-- 1 sgs sgs 986 03.01.2020 21:09 meta.xml
-rw-r--r-- 1 sgs sgs 39 03.01.2020 21:09 mimetype
-rw-r--r-- 1 sgs sgs 12K 03.01.2020 21:09 settings.xml
-rw-r--r-- 1 sgs sgs 18K 03.01.2020 21:09 styles.xml
I think you memorized it all faster than you memorized it on your computer. ![]()
Dos not work with discourse , I think.
with FF.
Great, then it’s easier to install and use Vivaldi. ![]()
For his needs.
In Firefox
i have been trying vivaldi and i got nothing, just a whole page in white ![]()
The forum also provides bookmarking, click on the three dots under the post and select the ribbon like button and the post will be bookmarked in your profile.
@Bryanpwo thanks but i’m looking for something that i can keep in an external memory, in case some problems with the system – it is usualy what happen … ![]()
You can try this…I am sorry and not on a linux box right now but it works on this machine and should work on linux. I highlighted everything from the beginning of the thread to the end. Select copy. Open you choice of word processing application. Right click on a blank document and then select paste. the flags and emoji’s a a little big but there may be a way around it…you’l have to play with it.
As @ringo suggested, I use Zim. It consists of a simple editor, stores entries in simple text format files (one for each topic), easy to back up, easy to search, easy to use.
@CMarch, Thanks, yes, that is the only solution till now, to store the links with anything …
I don’t easily give up, in case your system goes south, you can also use your phone or the live-environment of the ISO and log in to your endeavour account to retrieve the bookmarked page in your profile. ![]()
Well, yes, it can be another solution.
I’m curious about why this navegators are having an option which can not be used at all.
