Hi. Last night I tried to install Easy Effects. The problem is that the audio is late for a few seconds (sometimes it can be 10 seconds). And sometimes CPU usage goes up with some filters activated. this is the result in inxi -A
[renosp@reno-satellitel645 ~]$ inxi -A
Device-1: Intel 5 Series/3400 Series High Definition Audio
driver: snd_hda_intel
Sound Server-1: ALSA v: k5.17.9-arch1-1 running: yes
Sound Server-2: PipeWire v: 0.3.51 running: yes
After I uninstalled the sound returned to normal and had no intention of using Easy Effects again.
Did you setup your latencies in pipewire? If CPU usage went up likely Pipewire attempted to ensure playback continued so latency went through the roof.
