I was reading the information here about the mirros but it is very confused to me … what are the mirros that i have to have?. it looks that there are two main repos one for endeavouros and another, for arch?.
First, the mirrorlist shows a complete list of the web servers which maintain copies of the applications stored under the main repositories. Secondly, the app ‘reflector’ is a way to place the nearest and fastest web servers at the top of the list and delete all the rest. If you read the Arch Wiki for ‘reflector’ it gives simple examples of what to type on the command line. It is actually very, very simple and I recommend you read it. For example, in the UK, I would type:
After clicking OK, it will take a minute getting it set up, then return asking if you want to save the results. Say yes, enter your password, and you will have a new, customized mirrorlist ready to go.
If you hold the left ALT key, and use the right mouse button to drag the window upward - all should be well. (this assumes you are in XFCE - there may be a similar ability in other DEs, but I am not up on all of them).
ok i managed to shrink it for now and be able to activate it with an xfce4 application: ‘Appearance’.
This is what it gives me now, isn’t it too much? How do I know what is the basic thing to leave …?
################# Arch Linux mirrorlist generated by Reflector #################
# With: reflector -c US --protocol https --age 2 --sort rate --number 10
# When: 2020-09-02 14:42:15 UTC
# From: https://www.archlinux.org/mirrors/status/json/
# Retrieved: 2020-09-02 14:42:13 UTC
# Last Check: 2020-09-02 13:27:07 UTC
## United States
Server = https://mirror.mia11.us.leaseweb.net/archlinux/$repo/os/$arch
## United States
Server = https://iad.mirrors.misaka.one/archlinux/$repo/os/$arch
## United States
Server = https://mirror.wdc1.us.leaseweb.net/archlinux/$repo/os/$arch
## United States
Server = https://mirror.dal10.us.leaseweb.net/archlinux/$repo/os/$arch
## United States
Server = https://plug-mirror.rcac.purdue.edu/archlinux/$repo/os/$arch
## United States
Server = https://arlm.tyzoid.com/$repo/os/$arch
## United States
Server = https://arch.mirror.square-r00t.net/$repo/os/$arch
## United States
Server = https://mirror.kaminski.io/archlinux/$repo/os/$arch
## United States
Server = https://mirror.lty.me/archlinux/$repo/os/$arch
## United States
Server = https://mirror.sfo12.us.leaseweb.net/archlinux/$repo/os/$arch
GNU nano 5.2 /etc/pacman.d/mirrorlist
## United States
## United States
## United States
## United States
## United States
^G Ayuda^O Guardar^W Buscar^K Cortar^T Ejecutar ^C Ubicación
^X Salir^R Leer fich. ^\ Reemplazar ^U Pegar^J Justificar ^_ Ir a línea
GNU nano 5.2 /etc/pacman.d/endeavouros-mirrorlist
### [endeavouros]
### SigLevel = PackageRequired
### Include = /etc/pacman.d/endeavouros-mirrorlist
## Germany
Server = https://mirror.alpix.eu/endeavouros/repo/$repo/$arch
## Github
Server = https://github.com/endeavouros-team/mirrors/releases/download/mirror1/
Server = https://raw.githubusercontent.com/endeavouros-team/repo/master/$repo/$arch
## Sweden
#Server = https://mirror.linux.pizza/endeavouros/repo/$repo/$arch
[ 22 líneas leídas ]
┌11:02:08 WD= [~]
└───freebird@nest ─▶$ cat /etc/pacman.d/mirrorlist
# With: reflector -c CA -c US --protocol https --age 2 --sort rate --number 10
# When: 2020-07-08 02:35:14 UTC
# Retrieved: 2020-07-08 02:34:43 UTC
# Last Check: 2020-07-08 02:22:23 UTC
## Canada
Server = https://mirror.sergal.org/archlinux/$repo/os/$arch
## United States
Server = https://mirrors.kernel.org/archlinux/$repo/os/$arch
## United States
## United States
Server = https://arch.mirror.constant.com/$repo/os/$arch
## United States
## Canada
Server = https://muug.ca/mirror/archlinux/$repo/os/$arch
## United States
Server = https://ord.mirror.rackspace.com/archlinux/$repo/os/$arch
## United States
## United States
Server = https://iad.mirror.rackspace.com/archlinux/$repo/os/$arch
## United States
Server = https://mirrors.rit.edu/archlinux/$repo/os/$arch
and my EnOS mirrorlist:
EnOS mirrorlist
### EndeavourOS Repository Mirrorlist ###
#### Entry in file /etc/pacman.conf:
### [endeavouros]
## Germany
## Sweden
Server = https://ftp.acc.umu.se/mirror/endeavouros/repo/$repo/$arch
## Github
Not all that different. Enjoy how they work, and worry only if they don’t…
