Problems formatting an SD card
Try
$ sudo wipefs --all /dev/sdb
/dev/sdb: 2 bytes were erased at offset 0x000001fe (dos): 55 aa
/dev/sdb: calling ioctl to re-read partition table: Success
and yet:
If you now try to create a new partition table using fdisk or gdisk. If that does not work the internal controller on the sdcard has likely detected a fault and has locked the card into read only mode.
