Firefox and Waterfox in arch and debian are giving this error when opening, most of the time, in other occasions the error does not appear and it opens without problems.
SEC_ERROR_OCSP_SERVER_ERROR
I have been googling and apparently there are different opinions on this matter, since it is a bug until it has to do with Adblock, which I have installed – i also have HTTP Everywhere and NoScript and I have reconfigured too about:config … many options.
But i have been using Firefox with all this extension and configurations for years, this has never happened before … it started early today with this problem.
I don’t know what other information to offer to better describe the problem if anything else is needed please let me know … Thank you.
What adblocker exactly do you use?
I always use 2 of those (with Chromium and Firefox).
In Firefox I use Adblock Ultimate and uBlocker Origin (which in my opinion ist the best adblocker available).
I never had any problems.
@BONK I saw it before in google but i don’t understoo …, Sorry, but where in Firefox or Xfce4 are these … Options->Advanced->Certificates-> Validation?
@Trekkie00 Adblock Plus (no, i’m not saying it is the origen of the problem, i don’t know nothing about the cause.)
Is it only Waterfox or also Firefox?
As far as I know Waterfox is based on an older Firefox version (ESR). And they are supposed to be quite slow with security updates. That could be an explanation for your issues.
They both have the same problem, even Firefox-dev too …
Years ago I ruled out the use of other browsers due to the great capacity to make modifications and configure firefox compared to the limitations that others have. I will read later what you recommend. Thank you…
[keos@keos-pc ~]$ pacman -Qs mozilla
local/ca-certificates-mozilla 3.51-1
Mozilla's set of trusted CA certificates
local/firefox 74.0.1-1
Standalone web browser from mozilla.org
local/uchardet 0.0.6-2
Encoding detector library ported from Mozilla
[keos@keos-pc ~]$
You might want to uninstall your adblocker and see if that fixes the problem? I use AdGuard Adblocker on both Firefox and Chrome, and they work great. You can try it and see!
