Problème USB3 - xhci-pci
Bonjour
Depuis quelques jours ma carte pci express Usb 3 n’est plus reconnue.
Quelqu’un a une idée?
Merci!
Noyau 5.14.16-arch1-1
journalctl -p 3 -b `
nov. 09 10:08:14 ordi-m5640 kernel: xhci_hcd 0000:03:00.0: can’t setup: -110
nov. 09 10:08:14 ordi-m5640 kernel: xhci_hcd 0000:03:00.0: init 0000:03:00.0 fail, -110
nov. 09 10:08:18 ordi-m5640 wpa_supplicant[709]: nl80211: kernel reports: Authentication algorithm >
nov. 09 10:08:29 ordi-m5640 wpa_supplicant[709]: nl80211: kernel reports: Authentication algorithm >
nov. 09 10:08:29 ordi-m5640 wpa_supplicant[709]: bgscan simple: Failed to enable signal strength mo>
nov. 09 10:08:52 ordi-m5640 lightdm[788]: gkr-pam: unable to locate daemon control file
nov. 09 10:08:52 ordi-m5640 lightdm[806]: gkr-pam: couldn’t run gnome-keyring-daemon: Permission de>
nov. 09 10:08:52 ordi-m5640 lightdm[788]: gkr-pam: gnome-keyring-daemon didn’t start properly
nov. 09 10:26:56 ordi-m5640 kernel: nouveau 0000:02:00.0: fifo: fault 00 [READ] at 0000000000281000>
lines 1-10/10 (END)
sudo dmesg | grep xhci
[ 6.284172] xhci_hcd 0000:03:00.0: failed to load firmware renesas_usb_fw.mem, fallback to ROM
[ 6.284370] xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 6.284380] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 3
[ 16.284407] xhci_hcd 0000:03:00.0: can’t setup: -110
[ 16.284414] xhci_hcd 0000:03:00.0: USB bus 3 deregistered
[ 16.284521] xhci_hcd 0000:03:00.0: init 0000:03:00.0 fail, -110
[ 16.284525] xhci_hcd: probe of 0000:03:00.0 failed with error -110
03:00.0 USB controller: Renesas Technology Corp. uPD720201 USB 3.0 Host Controller (rev 03) (prog-if 30 [XHCI])
Flags: fast devsel, IRQ 19
Memory at febfe000 (64-bit, non-prefetchable) [size=8K]
Capabilities:
Kernel modules: xhci_pci
Bienvenue. Il existe un package dans l’AUR qui contient le logiciel de la puce Renesas. Pour l’installer, utilisez la commande.
yay -S upd72020x-fw
Edit: Ceci est spécifiquement pour l’erreur concernant la puce USB Renesas. Vous avez également d’autres messages d’erreur liés à pam. Je ne suis pas sûr que votre système fonctionne. Si tel est le cas, certains messages d’erreur peuvent ne pas être un problème.
Faites-nous savoir si vous avez d’autres difficultés.
J’ai installé upd72020x-fw et j’ai eu un plantage après le Grub…
En recovery j’ai obtenu les messages d’erreurs :
  • got firmware version 2006
  • xhci-hcd timeout dor datax step
  • position 136 bytes with (-110)
    Cette carte achetée il y a deux mois avait fonctionné Out of the Box sans aucune installation. Depuis samedi elle n’est plus reconnue.
    Etrange…
j ai rencontré le même souci il y a quelques temps sur plusieurs cartes équipéés du même chipset que la tienne, la seule façon de les refaire fonctionner a été de flasher le firmware constructeur avec une clé usb bootable DOS, depuis plus aucun souci.
Si tu veux plus de détails, dis-moi
@Bonjour
Je suis désolé que ce soit arrivé. Peut-être que comme le suggère @badplugin , vous pouvez essayer.
Bonjour
Oui merci pour cette solution. Je vais essayer.
Quelle est donc le protocole à suivre?
J’ai aussi faire une recherche avec " Renesas uPD720201/720202 USB 3.0 bios update" et " Renesas/Nec uPD720201/720202 USB 3.0 Firmware Version"
Merci
Ok, tout devrait bien ce passer.
Dans un premier temps assures toi de connaître quelle touche appuyer pour démarrer sur une clé usb au démarrage du PC (varie selon marque), ensuite il faut créer une disquette DOS bootable en utilisant unebootin par exemple ou rufus si tu as un windows sous la main, dans les 2 cas tu dois choisir Freedos, une fois la clé prête il faut copier les fichiers du firmware Renesas sur la clé en acceptant de remplacer le AUTOEXEC.BAT lors de la copie, une fois cela effectué redémarre le PC en bootant sur la clé usb et laisse faire, y 'en a pour très peu de temps, ensuite redémarre ton PC et ça devrait fonctionner.
IMPORTANT : avant toute chose supprime le upd72020x-fw (yay -R upd72020-fw)
Firmware Renesas à décompresser et à copier sur la clé :
Hash de l’archive :
hash renesas
Merci de nous tenir informé.
Comme j le dis toujours “USE IT AT YOUR OWN RISK”
Merci. Je teste. Du Dos , autoexec.bat… ça me rappelle de vieux souvenirs!
Génial. Ça marche !
Pour faire la clef Dos. J’ai essayé avec Unetbootin mais le fichier autoexec.bat était introuvable…
J’ai refait la clef de boot avec la fonction Restaurer l’Image Disque Disque de “Gnome Disque” et là cela a fonctionné! Mise à jour K2026090.mem 2.0.2.6 du 2019/05/10 réussie!
Encore Merci!
Avec plaisir.
:slightly_smiling_face:
