Problème de mise à jour EndeavourOS
bonjour à tous,
Pour faire original, j’ai remis à jour mon système EndeavourOS ce matin, visiblement tout a eu l’air de bien se passer sauf qu’au redémarrage je constate que mon système se bloque net au moment de charger le module de la carte graphique (une nvidia gt710)., à priori je pense que c’est ça …
message affiché en tapant systemctl --failed
“systemd-module-load service failed”
J’ai réinstallé systemd mais ça ne résoud rien … j’ai réinstallé linux-firmware également mais sans succès !
Si quelqu’un à une idée …!
Un salut à toute l’équipe d’EndeavourOS !
Cordialement
Je viens de regarder et ça m’a tout l’air d’être la carte graphique en cause
en tapant un : systemct status systemd-modules-load.service
j’ai ce message explicite:
systemd-modules-load[487]: failed to insert module “nvidia_uvm” = Invalid argument
Faut-il réinstaller le driver de la carte nvidia ?
Cdlt
good evening philou.
the solution to this problem is to switch into a different TTY (ctrl+alt+F3), login like normal and once again do a update.
A system core package was updated which seemingly had a bug included.
executing a simple sudo pacman -Syu should fix this problem, as above mentioned package was downgraded in the repos again. Here is the link to the post explaining this as well.
I have already done a sudo pacman -Syu and upgraded my system … 2 or 3 files were installed and I rebooted but with exactly the same result … Dont know what to do !
Thank you for your help Creatux !
You’re very welcome!
Wish you a good rest of your evening and good night for later :slight_smile:
Exactly the same problem as mentioned …
[stuck at ”Reached target graphical interface”]
oh, my Bad. misread that
could you run journalctl -b -0 | eos-sendlog and post the link that gives you here?
I am going to try …
could be it needs to reinstall nvidia-dkms if it already built the modules in a faulty way it will not rebuild on downgrading pahole i think …
deepl:
l se peut qu’il ait besoin de réinstaller nvidia-dkms s’il a déjà construit les modules d’une manière défectueuse, il ne les reconstruira pas lors de la rétrogradation de pahole, je pense…
the link seems to be this one
https://clbin.com/ELnoF
so i have to do a nvidia-dkms … I have tried to reinstall the Nvidia driver 470 but with no success with the command : nvidia-inst --series 470
! Thank a lot
La barrière de la langue, encore !
La solution a déjà été évoquée plus haut.
(Vive la grande nation qui refuse d’apprendre l’anglais !)
:rofl:
i see you stealin x3
jk :smiley:
Yer definitely not talking about BMW (they have an x3-model), AFAICT?
Not trying to “police” anything here, just not getting what you mean by x3?
I have good news … my problem is solved with the help of Joekamprad …
I made a : sudo pacman -S nvidia-470xx-dkms
and I restarted my system … Everything seems to work well now !
Thank you so much to everyone and specially to Joekamprad
supposed to be an emote lol
a crosseyed smilling cat afaik
Thanks a lot , this was the good solution
I typed : sudo pacman -S nvidia-470xx-dkms
and restarted my machine . Everything is OK now !
Thank you so much
now it is appropriate to say:
You’re welcome ^~^
(yes i know that that was meant for joe :p)
la solution ne fonctionne pas exactement avec les commandes indiquées !
sudo pacman -Syu
reboot
et voilà !
