Problem with setting Wi-FI
I spammed systemctl restart and I made it stop
wpa_supplicant.service - WPA supplicant
     Loaded: loaded (/usr/lib/systemd/system/wpa_supplicant.service; disabled; preset: disabled)
     Active: failed (Result: start-limit-hit) since Mon 2023-03-06 00:38:44 EET; 13s ago
   Duration: 486ms
    Process: 4428 ExecStart=/usr/bin/wpa_supplicant -u -s -O /run/wpa_supplicant (code=exited, status=0/SUCCESS)
   Main PID: 4428 (code=exited, status=0/SUCCESS)
        CPU: 3ms
mar 06 00:38:43 calin-15ach6h wpa_supplicant[4428]: Successfully initialized wpa_supplicant
mar 06 00:38:44 calin-15ach6h systemd[1]: Stopping WPA supplicant...
mar 06 00:38:44 calin-15ach6h systemd[1]: wpa_supplicant.service: Deactivated successfully.
mar 06 00:38:44 calin-15ach6h systemd[1]: Stopped WPA supplicant.
mar 06 00:38:44 calin-15ach6h systemd[1]: wpa_supplicant.service: Start request repeated too quickly.
mar 06 00:38:44 calin-15ach6h systemd[1]: wpa_supplicant.service: Failed with result 'start-limit-hit'.
mar 06 00:38:44 calin-15ach6h systemd[1]: Failed to start WPA supplicant.
mar 06 00:38:48 calin-15ach6h systemd[1]: wpa_supplicant.service: Start request repeated too quickly.
mar 06 00:38:48 calin-15ach6h systemd[1]: wpa_supplicant.service: Failed with result 'start-limit-hit'.
mar 06 00:38:48 calin-15ach6h systemd[1]: Failed to start WPA supplicant.
I will probably reinstall the distribution . Wi-Fi used ti work 4 months ago
Are you referring to using this?
Yes
Do you have no ca certificate required checked?
Edit: I know these are always a pain to get to work if the settings aren’t correct.
I dont use CA certificate. But I use Protected EAP (PEAP) with MSCHAPv2
All i know is it can be a pain. I have to connect to the same at my work and sometimes it doesn’t want to work.
Edit: Hard to say what the issue is. Could be an update? :man_shrugging:
Yes. It used to work in October. But then I had to use Windows for a bit of time and when I come back to make updates, I noticed the problem. Also it seems to refuse to boot when my GPU MUX switch is set to the Nvidia GPU. Now I run on iGPU.
I think I will reinstall. I spent 4 days searching with no luck. I am not an expert by any means, but I have a bit of experience with Manjaro and Linux Mint. :slight_smile:
Up to you. I hope it works out.
