Hystrix
December 19, 2020, 8:36am
1
I reinstall EnOS yesterday on my laptop and found out today that plugging in my headphone does not change the out put device . The device is listed in pavucontrol . But it shows the headphone is unplugged all the time , i.e. if it’s plugged in or not pavucontrol shows it’s unplugged . I can manually switch the output to headphone . Then headphone will work . But when I unplug it the audio is not switched to speakers . I have to do it manually .
System specs
Intel Pentium 4417u
4 GB RAM
Kernel 5.9.14-arch-1
XFCE DE
These two screenshots were taken when the headphone was not plugged in
alsamixer
pavucontrol
Plugging in the headphone does not make any difference to these screenshots
Also I noticed gwenview is listed in xfce4-pulseaudio-plugin though I never played a video in gwenview . I have seen some posts about an extra loopback in pulseaudio in some forums but not any issue like this
zangoku
December 19, 2020, 9:29am
2
Do you by any chance have a line-out option in output devices? I found this and seemed quite like your issue https://www.ghacks.net/2019/08/13/fix-for-no-sound-issue-on-linux-when-using-headphones/
Hystrix
December 19, 2020, 12:34pm
3
The problem is same but it’s not a solution . He is just sticking with the default output and don’t plan to change the device . That’s not the case with my laptop , I have to use it with headphones and speakers and changing the device manually every time is not a good option
do you have this inside your: /etc/pulse/default.pa ?
# automatically switch to newly-connected devices
load-module module-switch-on-connect
Hystrix
December 19, 2020, 1:21pm
5
It didn’t . So I added them and it doesn’t seem to change anything
Am I missing something
already try to reset pulse for your user?
mv ~/.config/pulse ~/.config/old-pulse
and issue could be also on alsa level, something like Auto-Mute Mode is enabled inside alsamixer?
i am still workingon that wiki it needs some commands and info on pulseaudio to nail down issues more easy…
it great … my go for audio problem
pacmd - Reconfigure a PulseAudio sound server during runtime
pacmd --help
pacmd exit
pacmd help
pacmd list-(modules|sinks|sources|clients|cards|samples)
pacmd list-(sink-inputs|source-outputs)
pacmd stat
pacmd info
pacmd load-module NAME [ARGS ...]
pacmd unload-module NAME|#N
pacmd describe-module NAME
pacmd set-(sink|source)-volume NAME|#N VOLUME
pacmd set-(sink-input|source-output)-volume #N VOLUME
pacmd set-(sink|source)-mute NAME|#N 1|0
pacmd set-(sink-input|source-output)-mute #N 1|0
pacmd update-(sink|source)-proplist NAME|#N KEY=VALUE
pacmd update-(sink-input|source-output)-proplist #N KEY=VALUE
pacmd set-default-(sink|source) NAME|#N
pacmd kill-(client|sink-input|source-output) #N
pacmd play-sample NAME SINK|#N
pacmd remove-sample NAME
pacmd load-sample NAME FILENAME
pacmd load-sample-lazy NAME FILENAME
pacmd load-sample-dir-lazy PATHNAME
pacmd play-file FILENAME SINK|#N
pacmd dump
pacmd move-(sink-input|source-output) #N SINK|SOURCE
pacmd suspend-(sink|source) NAME|#N 1|0
pacmd suspend 1|0
pacmd set-card-profile CARD PROFILE
pacmd set-(sink|source)-port NAME|#N PORT
pacmd set-port-latency-offset CARD-NAME|CARD-#N PORT OFFSET
pacmd set-log-target TARGET
pacmd set-log-level NUMERIC-LEVEL
pacmd set-log-meta 1|0
pacmd set-log-time 1|0
pacmd set-log-backtrace FRAMES
-h, --help Show this help
--version Show version
When no command is given pacmd starts in the interactive mode.
pacmd list-sinks
will show info about connected output-input-devices
Hystrix
December 19, 2020, 4:17pm
11
I disabled it and no effect .
Will try this out now !
systemctl --user restart pulseaudio.socket
after moving configs out of the way should be good to go, but a reboot will do also…
Hystrix
December 19, 2020, 4:32pm
13
Did a reboot but no luck . The problem persists . Along with a new one , there is an Unplugged Headphone listed in input section . Just noticed it now . The problem is not that the device is not recognized . Rather the device is shown as Unplugged when it’s plugged in . It shouldn’t even be there on the list when unplugged , but still is there (as unplugged headphone) and the microphone too .
pacmd list-sinks
1 sink(s) available.
* index: 0
driver: <module-alsa-card.c>
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 30129 / 46% / -20.25 dB, front-right: 30129 / 46% / -20.25 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 .. 2000.00 ms
card: 0 <alsa_card.pci-0000_00_1f.3>
module: 6
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC255 Analog"
alsa.id = "ALC255 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
alsa.card_name = "HDA Intel PCH"
alsa.long_card_name = "HDA Intel PCH at 0xb1320000 irq 132"
alsa.driver_name = "snd_hda_intel"
device.bus_path = "pci-0000:00:1f.3"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.vendor.name = "Intel Corporation"
device.product.id = "9d71"
device.product.name = "Sunrise Point-LP HD Audio"
device.form_factor = "internal"
device.string = "front:0"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Built-in Audio Analog Stereo"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
ports:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
device.icon_name = "audio-speakers"
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
device.icon_name = "audio-headphones"
active port: <analog-output-speaker>
What is your hardware? inxi -Fxxxa --no-host
could you try while watching journal to plugin the headphone?
journalctl -f in a term and then plugin the headphone, and copy paste what it shows.
Hystrix
December 19, 2020, 5:37pm
17
journalctl -f
-- Journal begins at Sat 2020-12-19 21:48:37 IST. --
Dec 19 23:04:11 ame-pc kernel: pcieport 0000:00:1c.0: device [8086:9d14] error status/mask=00003000/00002000
Dec 19 23:04:11 ame-pc kernel: pcieport 0000:00:1c.0: [12] Timeout
Dec 19 23:04:43 ame-pc kernel: pcieport 0000:00:1c.0: AER: Corrected error received: 0000:00:1c.0
Dec 19 23:04:43 ame-pc kernel: pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
Dec 19 23:04:43 ame-pc kernel: pcieport 0000:00:1c.0: device [8086:9d14] error status/mask=00003000/00002000
Dec 19 23:04:43 ame-pc kernel: pcieport 0000:00:1c.0: [12] Timeout
Dec 19 23:04:53 ame-pc kernel: pcieport 0000:00:1c.0: AER: Corrected error received: 0000:00:1c.0
Dec 19 23:04:53 ame-pc kernel: pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
Dec 19 23:04:53 ame-pc kernel: pcieport 0000:00:1c.0: device [8086:9d14] error status/mask=00001000/00002000
Dec 19 23:04:53 ame-pc kernel: pcieport 0000:00:1c.0: [12] Timeout
Dec 19 23:05:47 ame-pc kernel: pcieport 0000:00:1c.0: AER: Corrected error received: 0000:00:1c.0
Dec 19 23:05:47 ame-pc kernel: pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
Dec 19 23:05:47 ame-pc kernel: pcieport 0000:00:1c.0: device [8086:9d14] error status/mask=00003000/00002000
Dec 19 23:05:47 ame-pc kernel: pcieport 0000:00:1c.0: [12] Timeout
Hystrix
December 19, 2020, 5:43pm
18
When I tried to find the line
[Jack Headphone]
state.plugged = no
state.unplugged = unknown
in /usr/share/pulseaudio/alsa-mixer/paths/analog-output-lineout.conf
I found out that there is no /usr/share/pulseaudio folder .
Is that a problem ??
`inxi -Fxxxa --no-host
System: Kernel: 5.9.14-arch1-1 x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux root=UUID=5696a235-4f76-4e3b-8059-f93c78a448fe rw
rootflags=subvol=@ quiet
cryptdevice=UUID=6445586c-3f13-4865-82bd-6a98ba1040d3:luks-6445586c-3f13-4865-82bd-6a98ba1040d3
root=/dev/mapper/luks-6445586c-3f13-4865-82bd-6a98ba1040d3 loglevel=3 nowatchdog
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: EndeavourOS
Machine: Type: Laptop System: Acer product: Aspire A315-53 v: V2.02 serial: <superuser required>
Mobo: KBL model: Metapod_KL v: V2.02 serial: <superuser required> UEFI: Insyde v: 2.02 date: 01/03/2019
Battery: ID-1: BAT1 charge: 19.1 Wh condition: 24.7/37.0 Wh (67%) volts: 7.8/7.7 model: PANASONIC 004A354D36315041
type: Li-ion serial: 0000 status: Discharging
CPU: Info: Dual Core model: Intel Pentium 4417U bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: A (10) microcode: E0 L2 cache: 2 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18406
Speed: 800 MHz min/max: 400/2300 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5906
Device-2: Quanta VGA WebCam type: USB driver: uvcvideo bus ID: 1-7:4 chip ID: 0408:a031 serial: 0x0001
Display: x11 server: X.org 1.20.10 driver: intel unloaded: fbdev,modesetting,vesa
resolution: <missing: xdpyinfo>
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d71
Sound Server: ALSA v: k5.9.14-arch1-1
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI
driver: r8168 v: 8.048.03-NAPI modules: r8169 port: 3000 bus ID: 01:00.1 chip ID: 10ec:8168
IF: enp1s0f1 state: down mac: 98:28:a6:41:29:ff
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lite-On driver: ath10k_pci
v: kernel port: 3000 bus ID: 02:00.0 chip ID: 168c:0042
IF: wlan0 state: up mac: f8:a2:d6:84:fa:69
Device-3: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb bus ID: 1-5:3
chip ID: 04ca:3015
Drives: Local Storage: total: 465.76 GiB used: 65.4 GiB (14.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB block size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s serial: 29FXC12ZT rev: 2J
Partition: ID-1: / raw size: 465.27 GiB size: 465.27 GiB (100.00%) used: 65.4 GiB (14.1%) fs: btrfs dev: /dev/dm-0
maj-min: 254:0 mapped: luks-6445586c-3f13-4865-82bd-6a98ba1040d3
ID-2: /boot/efi raw size: 500 MiB size: 499 MiB (99.80%) used: 696 KiB (0.1%) fs: vfat dev: /dev/sda1
maj-min: 8:1
ID-3: /home raw size: 465.27 GiB size: 465.27 GiB (100.00%) used: 65.4 GiB (14.1%) fs: btrfs
dev: /dev/dm-0 maj-min: 254:0 mapped: luks-6445586c-3f13-4865-82bd-6a98ba1040d3
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: zram size: 1024 MiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C
Fan Speeds (RPM): N/A
Info: Processes: 214 Uptime: 1h 31m wakeups: 2 Memory: 3.72 GiB used: 2.15 GiB (57.7%) Init: systemd v: 247
Compilers: gcc: 10.2.0 Packages: pacman: 1028 lib: 249 Shell: Bash v: 5.1.0 running in: xfce4-terminal
inxi: 3.2.00
is alsa-utils installed?
sudo alsactl restore could help
also check if it is related to kernel drivers from latest kernel may LTS one do not have this issue…
@Hystrix
Have you installed sof-firmware?
reboot required
