Problem with Network
Hello! I recently started using EndeavourOS and I encountered this problem: the distro stopped seeing my network and says "Limited connection: This device is connected to the PC but does not have internet access.” DE: KDE Plasma 6.4.5.
I occasionally see this message when my Internet connection is fine, it just means it failed to ping it’s connection testing server. So if your net connection is otherwise fine, you can ignore it.
No, it doesn’t even go to websites and the tray icon has a yellow icon..(
Oh, I fix it (maybe), I had two connections. I turned one off and turned on the second one below, and it’s working for now. If this error occurs again, I’ll be sure to leave it in the answers. Thank!
