I’ve recently installed EOS on an ASUS Zenbook Flip UX360CA. Functionality wise everything works but I noticed the battery life is worse and the laptop runs hotter than it did with Windows. HTOP shows one of the CPU threads constantly runs around 35%, when the system should be idle. This is what’s causing the battery life and heat issues, as it’s stopping the CPU from clocking down like it should.
mpstat showed IRQ is what was spiking one of the CPU threads. Cat /proc/interrups shows this:
CPU0 CPU1 CPU2 CPU3
1: 0 0 153 0 IR-IO-APIC 1-edge i8042
8: 0 0 0 0 IR-IO-APIC 8-edge rtc0
9: 0 11 0 0 IR-IO-APIC 9-fasteoi acpi
16: 0 6622557 0 0 IR-IO-APIC 16-fasteoi idma64.0, i2c_designware.0, i801_smbus
17: 0 0 0 0 IR-IO-APIC 17-fasteoi idma64.1, i2c_designware.1
20: 123 0 0 0 IR-IO-APIC 20-fasteoi intel_ish_ipc
93: 0 0 99485 0 IR-IO-APIC 93-fasteoi FTSC1000:00
109: 0 3374 0 0 IR-IO-APIC 109-fasteoi ELAN1200:00
120: 0 0 0 0 DMAR-MSI 0-edge dmar0
121: 0 0 0 0 DMAR-MSI 1-edge dmar1
122: 0 0 0 0 IR-PCI-MSI 458752-edge PCIe PME, aerdrv
123: 0 0 0 15223 IR-PCI-MSI 376832-edge ahci[0000:00:17.0]
124: 0 0 0 233 IR-PCI-MSI 327680-edge xhci_hcd
125: 0 0 0 39 IR-PCI-MSI 360448-edge mei_me
126: 11795 0 0 0 IR-PCI-MSI 32768-edge i915
127: 0 0 0 1161 IR-PCI-MSI 524288-edge iwlwifi
128: 407 0 0 0 IR-PCI-MSI 514048-edge snd_hda_intel:card0
You’ll see number 16 has a huge number of interrupts for idma64.0, i2c_designware.0, and i801_smbus. I saw online someone had a similar issue with the i801 module and they fixed it by adding " i2c-i801.disable_features=0x10" to their GRUB cmdline to disable interrupts for it. I tried it but it didn’t fix my issue, interrupts were still high. I also saw someone blacklisted the designware driver by adding “initcall_blacklist=dw_i2c_init_driver” to their GRUB cmdline. Doing this causes both the touchpad and the touchscreen to stop functioning, but the IRQ storm does stop when this is disabled so this certainly seems to be related to the touchpad.
My input devices show up as
I: Bus=0018 Vendor=04f3 Product=301a Version=0100
N: Name="ELAN1200:00 04F3:301A Touchpad"
P: Phys=i2c-ELAN1200:00
S: Sysfs=/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-ELAN1200:00/0018:04F3:301A.0004/input/input21
U: Uniq=
H: Handlers=event7 mouse2
B: PROP=5
B: EV=1b
B: KEY=e520 10000 0 0 0 0
B: ABS=2e0800000000003
B: MSC=20
I: Bus=0018 Vendor=2808 Product=5112 Version=0100
N: Name="FTSC1000:00 2808:5112"
P: Phys=i2c-FTSC1000:00
S: Sysfs=/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-FTSC1000:00/0018:2808:5112.0005/input/input22
U: Uniq=
H: Handlers=event9 mouse3
B: PROP=2
B: EV=1b
B: KEY=400 0 0 0 0 0
B: ABS=3273800000000003
B: MSC=20
Pointer devices from xinput
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ ELAN1200:00 04F3:301A Mouse id=12 [slave pointer (2)]
⎜ ↳ ELAN1200:00 04F3:301A Touchpad id=13 [slave pointer (2)]
⎜ ↳ FTSC1000:00 2808:5112 id=14 [slave pointer (2)]
Another odd thing about it is that it’s inconsistent. Majority of the time I have this IRQ problem with the high CPU usage, but there are times when it boots up and runs fine with normal CPU usage and no IRQ storm. When that happens it will run fine for that entire session, but if I reboot it will most likely have the problem when it comes back up, even with no updates or configuration changes. There’s no rhyme or reason to it that I can discern.
I see the same problem on live sessions run from USB, so it’s not something specific to my installation.
I’m not really sure where I go from here. I’m hoping someone more experienced with kernel modules might have some ideas.
Thanks for any help.
