(nvidia-settings:23449): Gtk-WARNING **: 20:32:22.066: Failed to parse /etc/gtk-3.0/settings.ini: Keine Berechtigung
Gtk-Message: 20:32:22.101: Failed to load module “colorreload-gtk-module”
What does that means? What can i do?
I would first ask what version of conky you are running, and what bindings it has internally. Can you post the result of:
conky -v so I can see if the nVidia bindings are there?
conky 1.11.5_pre compiled Tue 30 Jun 2020 05:45:40 AM UTC for Linux 5.6.8-arch1-1 x86_64
Compiled in features:
System config file: /etc/conky/conky.conf
Package library path: /usr/lib/conky
General:
Music detection:
Default values:
Darn - I was hoping for easy here… but it appears you have a reasonably current conky, and it has the nVidia support bindings too. That error - what are the permissions for the file mentioned? (/etc/gtk-3.0/settings.ini)
As in
ls -l /etc/gtk-3.0/settings.ini
and maybe
cat /etc/gtk-3.0/settings.ini
as well? If nothing there tells me anything - we’ll have to call in the experts
[andi@endeavouros ~]$ ls -l /etc/gtk-3.0/settings.ini
-rw------- 1 root root 427 4. Okt 21:10 /etc/gtk-3.0/settings.ini
[andi@endeavouros ~]$ sudo cat /etc/gtk-3.0/settings.ini
[Settings]
gtk-application-prefer-dark-theme=false
gtk-button-images=true
gtk-cursor-theme-name=Hacked-White
gtk-decoration-layout=icon:minimize,maximize,close
gtk-enable-animations=true
gtk-font-name=Noto Sans, 10
gtk-icon-theme-name=Korla-Light
gtk-menu-images=true
gtk-modules=colorreload-gtk-module:appmenu-gtk3-module:appmenu-gtk-module
gtk-primary-button-warps-slider=false
gtk-theme-name=Arc-Darker
gtk-toolbar-style=3
I think, I´m talking with an expert
Thanks - but a definite exaggeration! All I can see is a possible permission glitch - and I don’t know if it helps… but
sudo chmod 644 /etc/gtk-3.0/settings.ini
and see if it helped.
If not - then real experts will be needed…
This is a warning so, unless it’s affecting something, you can probably ignore it without issue.
$ pacman -Ss color gtk
extra/colord-gtk 0.2.0-2
Additional GTK support code for colord
This is very cool, the nvidia settings warning is gone
What owns that file?
pacman -Qo /etc/gtk-3.0/settings.ini
[andi@endeavouros ~]$ pacman -Qo /etc/gtk-3.0/settings.ini
Fehler: Kein Paket besitzt /etc/gtk-3.0/settings.ini
OK, so it’s a file you created yourself? Hmm…
At least it’s not an issue caused by the EnOS installer.
Hmm, thats interesting. I haven´t created it myself!
color gtk doesn´t help me, have you other ideas?
Not for this, you’ve already fixed the issue.
