Well. I’m trying to install my Alpa AUWS036ACH and it has worked on all my other systems that don’t run EOS.
I’m using the rtl8812au driver as you should but linux-headers 6.12.8.arch1-1 doesn’t seem to be suitable for this.
This card works fine when it comes to connecting to networks etc, but what I need is to put it in monitor mode, but that’s where it all goes wrong: julle@HaxBox rtl8812au]$ sudo iw dev wlan0 set type monitor
command failed: Operation not supported (-95)
iv been try to install the drivers with different methods but the method I used on previous systems has been via git but it doesn’t work here, when I run make I get this:
julle@HaxBox rtl8812au]$ cd /home/julle/Downloads/rtl8812au
make
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/6.12.4-arch1-1/build M=/home/julle/Downloads/rtl8812au modules
make[1]: Going to directory "/home/julle/Downloads/rtl8812au"
make[1]: *** /lib/modules/6.12.4-arch1-1/build: File or directory does not exist. Stopping.
make[1]: Leaving directory “/home/julle/Downloads/rtl8812au”
make: *** [Makefile:116: modules] Error 2
[julle@HaxBox rtl8812au]$ make
make[1]: Going to directory “/home/julle/Downloads/rtl8812au”
[julle@HaxBox rtl8812au]$ sudo pacman -S linux-headers=6.12.4-arch1-1
[sudo] password for julle:
error: Could not find target linux-headers=6.12.4-arch1-1
Some one know what to do?
