Problem while updating to Plasma 5.24
Guys, I am unable to update to plasma 5.24, these are the error messages I get.
Any ideas?
error: failed to commit transaction (conflicting files)
kde-cli-tools: /usr/bin/kde-open exists in filesystem (owned by kdebase-runtime)
kde-cli-tools: /usr/bin/keditfiletype exists in filesystem (owned by kdebase-runtime)
kde-cli-tools: /usr/bin/kioclient exists in filesystem (owned by kdebase-runtime)
kde-cli-tools: /usr/bin/kmimetypefinder exists in filesystem (owned by kdebase-runtime)
kde-cli-tools: /usr/bin/kstart exists in filesystem (owned by kdebase-runtime)
kde-cli-tools: /usr/bin/ksvgtopng exists in filesystem (owned by kdebase-runtime)
J.
Problem solved, had to remove some old AUR packages.
Did you ever get the virtual desktops working?
I have four virtual desktops in use, switching on the desktop via mouse wheel doesn’t work though.
What about the new overview option in desktops effects? If you use that then the mouse wheel does scroll between them.
Edit: I guess you still have to have the cursor on the widget in the taskbar. :thinking:
Edit2: At least meta w to switch isn’t too bad.
