I’m a newbie here, so my question is… After updating my system, one of the updated packages (Vivaldi Browser) needed in order to work properly a codecs pack called ffmpeg-extra. I’ve already solved that issue using $ yay -Syu vivaldi-codecs-ffmpeg-extra-bin but after the today’s update and when I try to re-install the codecs pack using the same command, I get this result:
Get “h ttps://aur.archlinux.org/rpc.php?arg%5B%5D=pup-git&arg%5B%5D=teamviewer&arg%5B%5D=telegram-desktop-bin&arg%5B%5D=vivaldi&arg%5B%5D=vivaldi-codecs-ffmpeg-extra-bin&type=info&v=5”: dial tcp: lookup aur.archlinux.org: Temporary failure in name resolution
Yes indeed. I am trying to reinstall the codecs for Vivaldi, as well as mailspring and other packages, but that is the first error that the command displays and aborts the process.
and I have no problem so can you try this instead? The only difference is your link is pre-compiled but these codecs don’t get updated often and don’t take long to compile anyway.
Hi Rob! I’ve tried, but it is a 754mb data file and my laptop is an old machine. It spent 4 hours procesing the data with no result. That’s why I tried to get the pre-compiled one.
I assumed you installed from the herecura repo (this is from a trusted user from arch), cos that’s what I’ve always done and I guessed it was the only way but maybe not, and I looked today and the codecs are now there in this repo (pretty sure they weren’t when I first installed) so if you add the herecura repo you can get both Vivaldi and the codecs from there.
Simply do the following and you can use pacman to install as usual (remember to run with -Syu to get the available list sync’d).
Add herecura repo to /etc/pacman.conf (directly above [core] is fine) as follows:
[herecura]
Server = https://repo.herecura.be/$repo/$arch
Hi again Rob! I think the link was in maintenance. This morning I tried and everything worked just perfect. Thanks for your help. I’m gonna mark this post as closed.
