Hello All.
On one of my computers I am attempting to install libxxf86misc, something I have installed with no problem on others of my computers running EOS (I have no idea what it actually does or if it is even needed but, for some reason, it is installed on those other computers).
Here is the output from my command line:
**[ultralap-6440-i5-2@ultralap-6440-i5-2 ~]$ yay -S libxxf86misc**
**:: Checking for conflicts...**
**:: Checking for inner conflicts...**
**[Aur:1] libxxf86misc-1.0.4-2**
** 1 libxxf86misc (Build Files Exist)**
**==> Packages to cleanBuild?**
**==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4)**
**:: PKGBUILD up to date, Skipping (1/1): libxxf86misc**
**==> Diffs to show?**
**:: (1/1) Parsing SRCINFO: libxxf86misc**
**==> Making package: libxxf86misc 1.0.4-2 (Sun 09 Aug 2020 04:24:37 PM EDT)**
**==> Retrieving sources...**
** -> Updating libXxf86misc git repo...**
**Fetching origin**
**==> Validating source files with sha256sums...**
** libXxf86misc ... Skipped**
**==> Making package: libxxf86misc 1.0.4-2 (Sun 09 Aug 2020 04:24:39 PM EDT)**
**==> Checking runtime dependencies...**
**==> Checking buildtime dependencies...**
**Fetching origin**
**==> Removing existing $srcdir/ directory...**
**==> Extracting sources...**
** -> Creating working copy of libXxf86misc git repo...**
**Cloning into 'libXxf86misc'...**
**done.**
**Switched to a new branch 'makepkg'**
**==> Sources are ready.**
**==> Making package: libxxf86misc 1.0.4-2 (Sun 09 Aug 2020 04:24:41 PM EDT)**
**==> WARNING: Using existing $srcdir/ tree**
**==> Removing existing $pkgdir/ directory...**
**==> Starting build()...**
**autoreconf: Entering directory `.'**
**autoreconf: configure.ac: not using Gettext**
**autoreconf: running: aclocal **
**autoreconf: configure.ac: tracing**
**autoreconf: running: libtoolize --copy**
**libtoolize: putting auxiliary files in '.'.**
**libtoolize: copying file './ltmain.sh'**
**libtoolize: Consider adding 'AC_CONFIG_MACRO_DIRS([m4])' to configure.ac,**
**libtoolize: and rerunning libtoolize and aclocal.**
**libtoolize: Consider adding '-I m4' to ACLOCAL_AMFLAGS in Makefile.am.**
**autoreconf: running: /usr/bin/autoconf**
**autoreconf: running: /usr/bin/autoheader**
**autoreconf: running: automake --add-missing --copy --no-force**
**configure.ac:18: installing './compile'**
**configure.ac:18: installing './config.guess'**
**configure.ac:18: installing './config.sub'**
**configure.ac:12: installing './install-sh'**
**configure.ac:12: installing './missing'**
**src/Makefile.am: installing './depcomp'**
**autoreconf: Leaving directory `.'**
**checking for a BSD-compatible install... /usr/bin/install -c**
**checking whether build environment is sane... yes**
**checking for a thread-safe mkdir -p... /usr/bin/mkdir -p**
**checking for gawk... gawk**
**checking whether make sets $(MAKE)... yes**
**checking whether make supports nested variables... yes**
**checking whether make supports the include directive... yes (GNU style)**
**checking for gcc... gcc**
**checking whether the C compiler works... yes**
**checking for C compiler default output file name... a.out**
**checking for suffix of executables... **
**checking whether we are cross compiling... no**
**checking for suffix of object files... o**
**checking whether we are using the GNU C compiler... yes**
**checking whether gcc accepts -g... yes**
**checking for gcc option to accept ISO C89... none needed**
**checking whether gcc understands -c and -o together... yes**
**checking dependency style of gcc... gcc3**
**checking for gcc option to accept ISO C99... none needed**
**checking how to run the C preprocessor... gcc -E**
**checking for grep that handles long lines and -e... /usr/bin/grep**
**checking for egrep... /usr/bin/grep -E**
**checking for ANSI C header files... yes**
**checking for sys/types.h... yes**
**checking for sys/stat.h... yes**
**checking for stdlib.h... yes**
**checking for string.h... yes**
**checking for memory.h... yes**
**checking for strings.h... yes**
**checking for inttypes.h... yes**
**checking for stdint.h... yes**
**checking for unistd.h... yes**
**checking whether __clang__ is declared... no**
**checking whether __INTEL_COMPILER is declared... no**
**checking whether __SUNPRO_C is declared... no**
**checking for pkg-config... /usr/bin/pkg-config**
**checking pkg-config is at least version 0.9.0... yes**
**checking build system type... x86_64-pc-linux-gnu**
**checking host system type... x86_64-pc-linux-gnu**
**checking for a sed that does not truncate output... /usr/bin/sed**
**checking if gcc supports -Werror=unknown-warning-option... no**
**checking if gcc supports -Werror=unused-command-line-argument... no**
**checking if gcc supports -Wall... yes**
**checking if gcc supports -Wpointer-arith... yes**
**checking if gcc supports -Wmissing-declarations... yes**
**checking if gcc supports -Wformat=2... yes**
**checking if gcc supports -Wstrict-prototypes... yes**
**checking if gcc supports -Wmissing-prototypes... yes**
**checking if gcc supports -Wnested-externs... yes**
**checking if gcc supports -Wbad-function-cast... yes**
**checking if gcc supports -Wold-style-definition... yes**
**checking if gcc supports -Wdeclaration-after-statement... yes**
**checking if gcc supports -Wunused... yes**
**checking if gcc supports -Wuninitialized... yes**
**checking if gcc supports -Wshadow... yes**
**checking if gcc supports -Wmissing-noreturn... yes**
**checking if gcc supports -Wmissing-format-attribute... yes**
**checking if gcc supports -Wredundant-decls... yes**
**checking if gcc supports -Wlogical-op... yes**
**checking if gcc supports -Werror=implicit... yes**
**checking if gcc supports -Werror=nonnull... yes**
**checking if gcc supports -Werror=init-self... yes**
**checking if gcc supports -Werror=main... yes**
**checking if gcc supports -Werror=missing-braces... yes**
**checking if gcc supports -Werror=sequence-point... yes**
**checking if gcc supports -Werror=return-type... yes**
**checking if gcc supports -Werror=trigraphs... yes**
**checking if gcc supports -Werror=array-bounds... yes**
**checking if gcc supports -Werror=write-strings... yes**
**checking if gcc supports -Werror=address... yes**
**checking if gcc supports -Werror=int-to-pointer-cast... yes**
**checking if gcc supports -Werror=pointer-to-int-cast... yes**
**checking if gcc supports -pedantic... yes**
**checking if gcc supports -Werror... yes**
**checking if gcc supports -Werror=attributes... yes**
**checking whether make supports nested variables... (cached) yes**
**checking how to print strings... printf**
**checking for a sed that does not truncate output... (cached) /usr/bin/sed**
**checking for fgrep... /usr/bin/grep -F**
**checking for ld used by gcc... /usr/bin/ld**
**checking if the linker (/usr/bin/ld) is GNU ld... yes**
**checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B**
**checking the name lister (/usr/bin/nm -B) interface... BSD nm**
**checking whether ln -s works... yes**
**checking the maximum length of command line arguments... 1572864**
**checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu format... func_convert_file_noop**
**checking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noop**
**checking for /usr/bin/ld option to reload object files... -r**
**checking for objdump... objdump**
**checking how to recognize dependent libraries... pass_all**
**checking for dlltool... no**
**checking how to associate runtime and link libraries... printf %s\n**
**checking for ar... ar**
**checking for archiver @FILE support... @**
**checking for strip... strip**
**checking for ranlib... ranlib**
**checking command to parse /usr/bin/nm -B output from gcc object... ok**
**checking for sysroot... no**
**checking for a working dd... /usr/bin/dd**
**checking how to truncate binary pipes... /usr/bin/dd bs=4096 count=1**
**checking for mt... no**
**checking if : is a manifest tool... no**
**checking for dlfcn.h... yes**
**checking for objdir... .libs**
**checking if gcc supports -fno-rtti -fno-exceptions... no**
**checking for gcc option to produce PIC... -fPIC -DPIC**
**checking if gcc PIC flag -fPIC -DPIC works... yes**
**checking if gcc static flag -static works... yes**
**checking if gcc supports -c -o file.o... yes**
**checking if gcc supports -c -o file.o... (cached) yes**
**checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes**
**checking whether -lc should be explicitly linked in... no**
**checking dynamic linker characteristics... GNU/Linux ld.so**
**checking how to hardcode library paths into programs... immediate**
**checking whether stripping libraries is possible... yes**
**checking if libtool supports shared libraries... yes**
**checking whether to build shared libraries... yes**
**checking whether to build static libraries... no**
**checking for XXF86MISC... no**
**configure: error: Package requirements (xproto x11 xextproto xext xf86miscproto) were not met:**
**Package 'xf86miscproto', required by 'virtual:world', not found**
**Consider adjusting the PKG_CONFIG_PATH environment variable if you**
**installed software in a non-standard prefix.**
**Alternatively, you may set the environment variables XXF86MISC_CFLAGS**
**and XXF86MISC_LIBS to avoid the need to call pkg-config.**
**See the pkg-config man page for more details.**
**==> ERROR: A failure occurred in build().**
** Aborting...**
**error making: %!s(func() string=0x55a10e397a60)**
**[ultralap-6440-i5-2@ultralap-6440-i5-2 ~]$**
Can anyone tell me what I should do to get this program installed on this particular computer? At present I do not know how to adjust the PKG_CONFIG-PATH nor do I know how to adjust the environment variables. (If anyone’s solution requires that I effect either of the above, please give me step-by-step instructions as to how to do it.)
I sincerely thank anyone who can help me with this problem.
Lawrence
