Hallo!
Ich bekomme beim Upgrade folgende Meldung angezeigt:
==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'fallback'
-> -k /boot/vmlinuz-linux -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-fallback.img -S autodetect
==> Starting build: 5.13.12-arch1-1
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [modconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: wd719x
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [filesystems]
-> Running build hook: [fsck]
==> Generating module dependencies
==> Creating xz-compressed initcpio image: /boot/initramfs-linux-fallback.img
==> Image generation successful
Was mich besorgt ist der Eintrag :
Wie bekomme ich die Meldung weg, bzw den Fehler beseitigt?
Mein System:
inxi -Fxxxzo
System: Kernel: 5.10.56-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: Xfce 4.16.0
tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0
Machine: Type: Laptop System: Acer product: Aspire 7250G v: V1.10 serial: <filter>
Mobo: Acer model: HMA71_BZ serial: <filter> BIOS: Insyde v: 1.10 date: 11/02/2011
Battery: ID-1: BAT0 charge: 29.6 Wh (100.0%) condition: 29.6/48.4 Wh (61.2%) volts: 12.1
min: 10.8 model: AS10B31 type: Li-ion serial: N/A status: Full
CPU: Info: Dual Core model: AMD E-450 APU with Radeon HD Graphics bits: 64 type: MCP
arch: Bobcat rev: 0 cache: L2: 512 KiB
flags: lm nx pae sse sse2 sse3 sse4a ssse3 svm bogomips: 6585
Speed: 826 MHz min/max: 825/1650 MHz Core speeds (MHz): 1: 826 2: 824
Graphics: Device-1: AMD Wrestler [Radeon HD 6320] vendor: Acer Incorporated ALI driver: radeon
v: kernel bus-ID: 00:01.0 chip-ID: 1002:9806 class-ID: 0300
Device-2: AMD Seymour [Radeon HD 6400M/7400M Series] vendor: Acer Incorporated ALI
driver: radeon v: kernel bus-ID: 01:00.0 chip-ID: 1002:6760 class-ID: 0300
Device-3: Chicony WebCam type: USB driver: uvcvideo bus-ID: 2-4:3 chip-ID: 04f2:b209
class-ID: 0e02
Display: x11 server: X.org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: ati,radeon unloaded: fbdev,modesetting,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: AMD PALM (DRM 2.50.0 / 5.10.56-1-lts LLVM 12.0.1)
v: 3.3 Mesa 21.2.1 compat-v: 3.1 direct render: Yes
Audio: Device-1: AMD Wrestler HDMI Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus-ID: 00:01.1 chip-ID: 1002:1314 class-ID: 0403
Device-2: AMD SBx00 Azalia vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Sound Server-1: ALSA v: k5.10.56-1-lts running: yes
Sound Server-2: JACK v: 1.9.19 running: no
Sound Server-3: PulseAudio v: 15.0 running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Network: Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Lite-On
driver: ath9k v: kernel port: 4000 bus-ID: 07:00.0 chip-ID: 168c:0032 class-ID: 0280
Device-2: Qualcomm Atheros AR8152 v2.0 Fast Ethernet vendor: Acer Incorporated ALI
driver: atl1c v: kernel port: 2000 bus-ID: 08:00.0 chip-ID: 1969:2062 class-ID: 0200
IF: enp8s0 state: down mac: <filter>
Drives: Local Storage: total: 566.22 GiB used: 107.89 GiB (19.1%)
ID-1: /dev/sda vendor: SanDisk model: SSD PLUS 480GB size: 447.13 GiB speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 04RL scheme: GPT
ID-2: /dev/sdb type: USB vendor: Generic model: Multi-Card size: 119.08 GiB
serial: <filter> rev: 1.00 scheme: MBR
Partition: ID-1: / size: 95.56 GiB used: 17.26 GiB (18.1%) fs: ext4 dev: /dev/sda3
ID-2: /home size: 342.92 GiB used: 90.64 GiB (26.4%) fs: ext4 dev: /dev/sda2
Swap: Alert: No swap data was found.
Unmounted: ID-1: /dev/sda1 size: 9 MiB fs: <superuser required> label: N/A uuid: N/A
ID-2: /dev/sdb1 size: 119.08 GiB fs: <superuser required> label: N/A
uuid: 9dc96360-7dd6-40c1-b98b-c92127d5151b
Sensors: System Temperatures: cpu: 56.0 C mobo: N/A
Fan Speeds (RPM): N/A
GPU: device: radeon temp: 46.0 C device: radeon temp: 56.0 C
Info: Processes: 157 Uptime: 1h 5m wakeups: 1 Memory: 5.53 GiB used: 1.75 GiB (31.7%)
Init: systemd v: 249 Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1279
Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.05
Vielen Dank im vorraus.
MfG R.Lehmeier
